I successfully used Audirvana 3.5.50 for more than half a year on my 2021 Macbook Air M1 with my Lyngdorf TDAI-1120 but since yesterday Audirvana doesn’t start to play the first track, no matter from which source. This problem only occurs on the Lyngdorf Amp, not on other devices of my LAN network (e.g. Naim Mu-So).
I’ve done no changes of any settings, nor a software update.
Can you help me please?
Here’s the Debug Info:
macOS 12.0.1 with 16384MB RAM
Registriert nach Michael Tröger
Bandwidth at 0dB = 90.0505
Max allowed volume: 99.1883
AUTO: /Users/michael/Library/Mobile Documents/com~apple~CloudDocs/iTunes
Library database path: /Users/michael/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
HRA-Streaming: Connected as VirtualVault
Preferred device: Lyngdorf TDAI-1120 Model UID:Lyngdorf Lyngdorf TDAI-1120 UID:uuid:6f5dff31-2592-446d-8ace-1c344079b2b4
UPnP device at http://192.168.178.30:56573/6f5dff31-2592-446d-8ace-1c344079b2b4.xml
ID 0x0 Lyngdorf TDAI-1120 Manufacturer:Lyngdorf
Volume control: No
http-get:*:text/xml:DLNA.ORG_PN=DIDL_S
http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=HEAACv2_L2_320
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE
http-get:*:audio/3gpp:DLNA.ORG_PN=HEAACv2_L2_320
http-get:*:audio/mp4:DLNA.ORG_PN=HEAACv2_L2_320
http-get:*:audio/l16;rate=48000;channels=1:DLNA.ORG_PN=LPCM
http-get:*:audio/l16;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get:*:audio/l16;rate=44100;channels=1:DLNA.ORG_PN=LPCM
http-get:*:audio/l16;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3
rtsp-rtp-udp:*:text/xml:DLNA.ORG_PN=DIDL_S
rtsp-rtp-udp:*:audio/vnd.dlna.adts:DLNA.ORG_PN=HEAACv2_L2_320
rtsp-rtp-udp:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL
rtsp-rtp-udp:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE
rtsp-rtp-udp:*:audio/3gpp:DLNA.ORG_PN=HEAACv2_L2_320
rtsp-rtp-udp:*:audio/mp4:DLNA.ORG_PN=HEAACv2_L2_320
rtsp-rtp-udp:*:audio/l16;rate=48000;channels=1:DLNA.ORG_PN=LPCM
rtsp-rtp-udp:*:audio/l16;rate=48000;channels=2:DLNA.ORG_PN=LPCM
rtsp-rtp-udp:*:audio/l16;rate=44100;channels=1:DLNA.ORG_PN=LPCM
rtsp-rtp-udp:*:audio/l16;rate=44100;channels=2:DLNA.ORG_PN=LPCM
rtsp-rtp-udp:*:audio/mpeg:DLNA.ORG_PN=MP3
http-get::audio/wav:
http-get::audio/m4a:
http-get::audio/x-flac:
http-get::audio/mpeg:
http-get::audio/mp4:
http-get::audio/aac:
http-get::audio/aiff:
http-get::audio/wave:
http-get::audio/3gpp:
http-get::text/xml:
http-get::audio/x-ms-wma:
http-get::application/ogg:
http-get::audio/vorbis:
http-get::audio/l16;rate=44100;channels=1:
http-get::audio/l16;rate=44100;channels=2:
http-get::audio/flac:
http-get::audio/x-aiff:
http-get::audio/x-m4a:
http-get::audio/x-wav:
http-get::audio/x-aac:
http-get::audio/ogg:
http-get::audio/l16;rate=48000;channels=1:
http-get::audio/l16;rate=48000;channels=2:
rtsp-rtp-udp::audio/wav:
rtsp-rtp-udp::audio/m4a:
rtsp-rtp-udp::audio/x-flac:
rtsp-rtp-udp::audio/mpeg:
rtsp-rtp-udp::audio/mp4:
rtsp-rtp-udp::audio/aac:
rtsp-rtp-udp::audio/aiff:
rtsp-rtp-udp::audio/wave:
rtsp-rtp-udp::audio/3gpp:
rtsp-rtp-udp::text/xml:
rtsp-rtp-udp::audio/x-ms-wma:
rtsp-rtp-udp::audio/vorbis:
rtsp-rtp-udp::audio/l16;rate=44100;channels=1:
rtsp-rtp-udp::audio/l16;rate=44100;channels=2:
rtsp-rtp-udp::audio/vnd.dlna.adts:
rtsp-rtp-udp::audio/flac:
rtsp-rtp-udp::audio/x-aiff:
rtsp-rtp-udp::audio/x-m4a:
rtsp-rtp-udp::audio/x-wav:
rtsp-rtp-udp::audio/x-aac:
rtsp-rtp-udp::audio/ogg:
rtsp-rtp-udp::audio/l16;rate=48000;channels=1:
rtsp-rtp-udp::audio/l16;rate=48000;channels=2:
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
12 virtual formats:
0 physical formats
NrTracks: 0
MediaDuration: 0:00:00
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
<?xml version="1.0"?>1
0
SetAVTransportURI
InstanceID
in
A_ARG_TYPE_InstanceID
CurrentURI
in
AVTransportURI
CurrentURIMetaData
in
AVTransportURIMetaData
SetNextAVTransportURI
InstanceID
in
NextURI
in
NextAVTransportURI
NextURIMetaData
in
NextAVTransportURIMetaData
GetMediaInfo
InstanceID
in
NrTracks
out
NumberOfTracks
MediaDuration
out
CurrentMediaDuration
CurrentURI
out
AVTransportURI
CurrentURIMetaData
out
NextURI
out
NextAVTransportURI
NextURIMetaData
out
PlayMedium
out
PlaybackStorageMedium
RecordMedium
out
RecordStorageMedium
WriteStatus
out
RecordMediumWriteStatus
GetMediaInfo_Ext
InstanceID
in
CurrentType
out
CurrentMediaCategory
NrTracks
out
NumberOfTracks
MediaDuration
out
CurrentURI
out
AVTransportURI
CurrentURIMetaData
out
NextURI
out
NextAVTransportURI
NextURIMetaData
out
PlayMedium
out
RecordMedium
out
RecordStorageMedium
WriteStatus
out
GetTransportInfo
InstanceID
in
out
TransportState
out
TransportStatus
CurrentSpeed
out
TransportPlaySpeed
GetCurrentTransportActions
InstanceID
in
Actions
out
GetPositionInfo
InstanceID
in
Track
out
CurrentTrack
TrackDuration
out
CurrentTrackDuration
TrackMetaData
out
CurrentTrackMetaData
TrackURI
out
CurrentTrackURI
RelTime
out
RelativeTimePosition
AbsTime
out
AbsoluteTimePosition
RelCount
out
RelativeCounterPosition
AbsCount
out
AbsoluteCounterPosition
GetDeviceCapabilities
InstanceID
in
PlayMedia
out
PossiblePlaybackStorageMedia
RecMedia
out
PossibleRecordStorageMedia
RecQualityModes
out
PossibleRecordQualityModes
GetTransportSettings
InstanceID
in
PlayMode
out
CurrentPlayMode
RecQualityMode
out
CurrentRecordQualityMode
Stop
InstanceID
in
Play
InstanceID
in
Speed
in
TransportPlaySpeed
Pause
InstanceID
in
Seek
InstanceID
in
Unit
in
A_ARG_TYPE_SeekMode
Target
in
A_ARG_TYPE_SeekTarget
Next
InstanceID
in
Previous
InstanceID
in
X_DLNA_GetBytePositionInfo
InstanceID
in
TrackSize
out
X_DLNA_CurrentTrackSize
RelByte
out
X_DLNA_RelativeBytePosition
AbsByte
out
X_DLNA_AbsoluteBytePosition
SetPlayMode
InstanceID
in
NewPlayMode
in
CurrentPlayMode
TransportState
string
STOPPED
PAUSED_PLAYBACK
PAUSED_RECORDING
PLAYING
RECORDING
TRANSITIONING
NO_MEDIA_PRESENT
TransportStatus
string
OK
ERROR_OCCURRED
string
NO_MEDIA
TRACK_AWARE
TRACK_UNAWARE
string
string
UNKNOWN
DV
MINI-DV
VHS
W-VHS
S-VHS
D-VHS
VHSC
VIDEO8
HI8
CD-ROM
CD-DA
CD-R
CD-RW
VIDEO-CD
SACD
MD-AUDIO
MD-PICTURE
DVD-ROM
DVD-VIDEO
DVD-R
DVD+RW
DVD-RW
DVD-RAM
DVD-AUDIO
DAT
LD
HDD
MICRO-MV
NONE
NOT_IMPLEMENTED
SD
PC-CARD
MMC
CF
BD
MS
HD_DVD
RecordStorageMedium
string
UNKNOWN
DV
MINI-DV
VHS
W-VHS
S-VHS
D-VHS
VHSC
VIDEO8
HI8
CD-ROM
CD-DA
CD-R
CD-RW
VIDEO-CD
SACD
MD-AUDIO
MD-PICTURE
DVD-ROM
DVD-VIDEO
DVD-R
DVD+RW
DVD-RW
DVD-RAM
DVD-AUDIO
DAT
LD
HDD
MICRO-MV
NONE
NOT_IMPLEMENTED
SD
PC-CARD
MMC
CF
BD
MS
HD_DVD
string
NONE
string
CurrentPlayMode
string
NORMAL
REPEAT_TRACK
REPEAT_ONE
REPEAT_ALL
NORMAL
TransportPlaySpeed
string
1
1
string
WRITABLE
PROTECTED
NOT_WRITABLE
UNKNOWN
NOT_IMPLEMENTED
string
0:EP
1:LP
2:SP
0:BASIC
1:MEDIUM
2:HIGH
NOT_IMPLEMENTED
string
NumberOfTracks
ui4
0
512
CurrentTrack
ui4
0
512
1
string
string
string
CurrentTrackURI
string
AVTransportURI
string
string
NextAVTransportURI
string
string
string
string
i4
i4
LastChange
string
A_ARG_TYPE_SeekMode
string
ABS_TIME
REL_TIME
TRACK_NR
ABS_COUNT
REL_COUNT
X_DLNA_REL_BYTE
string
ui4
string
string
string
0
qq:X_QPlay_SoftwareCapabilityQPlay:2.1</qq:X_QPlay_SoftwareCapability>
Lyngdorf TDAI-1120
Lyngdorf
TDAI-1120
http://lyngdorf.com/tdai-1120/
1907001890
image/png
120
120
24
/LibRygelRenderer-120x120x24.png
image/png
48
48
24
/LibRygelRenderer-48x48x24.png
image/jpeg
120
120
24
/LibRygelRenderer-120x120x24.jpg
image/jpeg
48
48
24
/LibRygelRenderer-48x48x24.jpg
/xml/ConnectionManager.xml
/Control/LibRygelRenderer/RygelSinkConnectionManager
/Event/LibRygelRenderer/RygelSinkConnectionManager
/xml/AVTransport2.xml
/Control/LibRygelRenderer/RygelAVTransport
/Event/LibRygelRenderer/RygelAVTransport
/xml/RenderingControl2.xml
/Control/LibRygelRenderer/RygelRenderingControl
/Event/LibRygelRenderer/RygelRenderingControl
urn:schemas-tencent-com:service:QPlay:1
urn:tencent-com:serviceId:QPlay
/xml/QPlayDescription.xml
/Control/LibRygelRenderer/QPlay
/Event/LibRygelRenderer/QPlay
dlna:X_DLNADOCDMR-1.51</dlna:X_DLNADOC>
UPnP devices found : 3
Device #0: ID 0x0 DP-UB420/424 UID: uuid:4D454930-0100-1000-8000-FFFFFFFFFFFF Location: http://192.168.178.28:60606/FFFFFFFFFFFF/Server0/ddd
Device #1: ID 0x0 Mu-so-15EB UID: uuid:5F9EC1B3-ED59-79BB-4530-E8C74F0A15EB Location: http://192.168.178.25:8080/description.xml
Device #2: ID 0x0 Lyngdorf TDAI-1120 UID: uuid:6f5dff31-2592-446d-8ace-1c344079b2b4 Location: http://192.168.178.30:56573/6f5dff31-2592-446d-8ace-1c344079b2b4.xml
Max. memory for audio buffers: 6856MB
Device #0: ID 0x2d MacBook Air Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
