Hello all,
I am having issues playing master songs on Tidal. It plays beautifully for 15 minutes or so, and then, all of a sudden, the sound gets crackling with intermitent noises. It gets worse if I turn SonEQ on.
I am running Audirvana, version 3.5.44 on win10 64 bit, i7, 20gb RAM, DAC is a MAudio Fast Track Ultra 8R which runs smoothly on other softwares.
Debug info
Audirvana 3.5.44
VST3 plugin #0: C:\Program Files\Common Files\VST3\SonEQFree.vst3
ClassID: F2AEE70D00DE4F4E536F6E69536F4551
VST3 plugin #1: None
VST3 plugin #2: None
VST3 plugin #3: None
Max allowed volume: 72.6886
SW volume control: ON
Sync list: 0 folders
Library database path: C:\Users\andre\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 256MB
Local Audio Engine:WASAPI
Line 1/2 (2- M-Audio Fast Track Ultra 8R)
Model UID:Line 1/2 (2- M-Audio Fast Track Ultra 8R)
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{0d6e8353-ab74-42b3-a97f-4ef90ac9f1f7}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device: 2ch 32bits Integer, 8 bytes per frame 96kHz
Active Sample Rate: 96kHz
Line 1/2 (2- M-Audio Fast Track Ultra 8R) Manufacturer:
Model UID:Line 1/2 (2- M-Audio Fast Track Ultra 8R) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{0d6e8353-ab74-42b3-a97f-4ef90ac9f1f7}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
1 available sample rates up to 96000Hz
Simple stereo device: No
Local devices found : 7
Device #0: Alto-falantes (Realtek(R) Audio) Manufacturer: Model UID: Alto-falantes (Realtek(R) Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{7de1433b-1aa5-4f55-9827-fdc1f2610547}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Alto-falantes (Waves SoundGrid) Manufacturer: Model UID: Alto-falantes (Waves SoundGrid) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{84f6166b-e0aa-45b8-b0f4-1439a32873e4}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #2: Line 1/2 (2- M-Audio Fast Track Ultra 8R) Manufacturer: Model UID: Line 1/2 (2- M-Audio Fast Track Ultra 8R) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{0d6e8353-ab74-42b3-a97f-4ef90ac9f1f7}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #3: Line 3/4 (2- M-Audio Fast Track Ultra 8R) Manufacturer: Model UID: Line 3/4 (2- M-Audio Fast Track Ultra 8R) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{8424f285-e066-4c28-b282-972438963d43}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #4: Line 5/6 (2- M-Audio Fast Track Ultra 8R) Manufacturer: Model UID: Line 5/6 (2- M-Audio Fast Track Ultra 8R) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{26ebff4d-91a7-4c61-8a8d-bcfbb6834cd9}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #5: S/PDIF (2- M-Audio Fast Track Ultra 8R) Manufacturer: Model UID: S/PDIF (2- M-Audio Fast Track Ultra 8R) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{b49bd8b4-2d7f-43f8-9cad-a5684ed31520}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #6: Alto-falantes (2- M-Audio Fast Track Ultra 8R) Manufacturer: Model UID: Alto-falantes (2- M-Audio Fast Track Ultra 8R) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{030abca2-5e77-444a-9afd-b5952a3aa0b3}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Any help is appreciated.
