Hi, I would like to stop my iTunes library syncing across to Audirvana Studio but cannot seem to do it. Does anybody have any suggestions?
Mark
Mark
Hello @organm,
Do you mean that if you try to remove it in the local settings of Audirvāna Studio it’s not working?
Hi, I just wanted to stop the synch/interface between my iTunes Library and Audirvana. I do not want iTunes music showing in Audirvana.
Can this be achieved?
Thanks Mark
Hi @organm, yes, you need to go at the same location in Audirvāna as I gave you in my previous post.
