I can’t hear the track completely that jumps directly to the next one missing 2 to 6 seconds of the previous one.
I m Using a Mac Mini 4 M and a separate DAC
Please help
If you’re upsampling, disable it.
Thks a lot l’OL try it
@ Damien request
Audirvana Mac Version 3.5.40 (3570)
macOS 10.13.6 with 4096MB RAM
Licence enregistrée pour marc wilkie
Per track: OFF
SW volume control: ON
Sync list: 2 folders
AUTO: /Users/marcwilkie/Music/Qobuz
AUTO: /Users/marcwilkie/Music/iTunes/iTunes Music
Library database path: /Users/marcwilkie/Music/iTunes/iTunes Music/AudirvanaPlusDatabaseV2.sqlite
Qobuz: Connected as Qobuz Hi-Fi Sublime
CoreAudio audio path, buffer I/O frame size: 4096
Max. memory for audio buffers: 616MB
Combo384 Amanero
Model UID:Combo384 Amanero:16D0:071A
UID:AppleUSBAudioEngine:Amanero Technologies:Combo384 Amanero:413-001:2
Device: 6ch Mixable linear PCM Interleaved 32bits little endian Signed Float, 24 bytes per frame 44.1kHz
Hog Mode is on
Sample rate switching latency: 3s
ID 0x2eb HDMI Manufacturer:Apple Inc.
Model UID:AppleHDA:88 UID:AppleHDAEngineOutputDP:1B,3,1,2:0:{D94D-C403-01010101}
5 available sample rates up to 96000Hz
32000
Multichannel: 6 channels
Channel bitmap: Ox3f, layout:
Channel 2 mapped to 2
Channel 3 mapped to 3
Channel 4 mapped to 4
Channel 5 mapped to 5
Number of channels: 6
Simple stereo device: No
Number of active channels: 6, in 1 stream(s)
Stream ID 0x2ec 6 channels starting at 1
8 virtual formats:
6 ch Mixable linear PCM Interleaved 32 little endian Signed Float 96kHz
6 ch Mixable linear PCM Interleaved 32 little endian Signed Float 88.2kHz
6 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
6 ch Mixable linear PCM Interleaved 32 little endian Signed Float 44.1kHz
6 ch Mixable linear PCM Interleaved 32 little endian Signed Float 32kHz
18 physical formats
6 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 96kHz
6 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 88.2kHz
6 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 48kHz
6 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 44.1kHz
6 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 32kHz
6 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 96kHz
6 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 88.2kHz
6 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 48kHz
6 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 44.1kHz
6 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 32kHz
6 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 96kHz
6 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 88.2kHz
6 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
6 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 44.1kHz
6 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 32kHz
Device #0: ID 0x31 Sortie intégrée Manufacturer: Apple Inc. Model UID: AppleHDA:88 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x2eb HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:88 UID: AppleHDAEngineOutputDP:1B,3,1,2:0:{D94D-C403-01010101}
UPnP devices found : 2
Device #0: ID 0x0 Décodeur TV UID: uuid:00ababad-7947-1048-8a00-181e7882b539 Location: http://192.168.1.59:42300/description.xml
Device #1: ID 0x0 KD-43X8309C UID: uuid:23456789-1234-1010-8000-ac9b0ae1335f Location: http://192.168.1.10:52323/MediaRenderer.xml
Does the issue you have occurs when tracks have a different sample rate?
Yes same with different Sample rate
Have you tried to deactivate Integer mode?
It seems to be the right solution
I have to try again a bit more but thanks for that
I m talking to the Bitracer solution
