Keep focus on main window
Studio 2.7. Sonoma 14.3.1. Mac M1 mini
I use a couple of AU plugins and I enable real time modifications, so there are two plugin windows plus the main window on screen. The problem is between every track, the plugin windows close then reopen and steal the focus away from the main window. Actually, I’m not sure where the focus goes; I only know I have to click once to bring the focus back to the main window. So it always takes two clicks to do what I want.
Seems like it’d be good to move the focus back to the main window automatically. Or at least have it as an option.
thanks
Hi @hifime,
Note: By clicking on the Debug Info button, Audirvana automatically copies all its content. All you have to do is paste it in response to this message.
Please excuse the delay in response.
Audirvana Studio 2.7.0 (20700)
macOS 14.3.1 with 16GB physical RAM
Connected account of : *********
        AU plugin #0: Music Effect - FabFilter Pro-Q 3 ()
        AU plugin #1: Music Effect - FabFilter Pro-R 2 ()
        AU plugin #2: None
        AU plugin #3: None
    SW volume control: ON
        AUTO: /Volumes/T7/Music
    Library database path: /Users/moi/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
    Tracks with no MBID: 3538
    Listening on 127.0.0.1 on port 56375
    TIDAL:  Connected as HiFi Plus
Max. memory for audio buffers: 2290MB
Local Audio Engine: CoreAudio
    Exclusive access: ON
    Integer mode: ON
    SMSL SMSL USB AUDIO
    Model UID:SMSL USB AUDIO:152A:85DD
    UID:AppleUSBAudioEngine:SMSL:SMSL USB AUDIO:2100000:1
    Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 44.1kHz
Hog Mode is on
Selected device:SMSL USB AUDIO
    Manufacturer: SMSL
    Model name: SMSL USB AUDIO
    Model UID: SMSL USB AUDIO:152A:85DD
    UID: AppleUSBAudioEngine:SMSL:SMSL USB AUDIO:2200000:1
    USB Vendor ID: 0x152a
    USB Product ID: 0x85dd
    ID 0xb1c
    Max volume alert: Disabled
    DSD via PCM 1.1
Stream ID 0xb1d 2 channels starting at 1
20 virtual formats:
20 physical formats
Local devices found : 5
    Device #0: ID 0xade DELL U2723QE
        Manufacturer: DEL
        Model UID: 10AC7942-0000-0000-3120-0104B53C2278
        Model name: DELL U2723QE
    Device #1: ID 0xaed LG TV
        Manufacturer: GSM
        Model UID: 1E6D0100-0000-0000-011B-010380A05A78
        Model name: GSM LG TV
    Device #2: ID 0xb01 OontZ Angle 3 F7F
        Model UID: 0 0
        UID: 7C-B1-6C-A9-4F-7F:output
        Model name: Apple Inc. OontZ Angle 3 F7F
    Device #3: ID 0xb1c SMSL USB AUDIO
        Manufacturer: SMSL
    Device #4: ID 0x4a Mac mini Speakers
        Model UID: Speaker
        UID: BuiltInSpeakerDevice
UPnP devices found : 1
    Device #0: ID 0x0 : Vimu on AFTKA
        UID: uuid:57a9475f-4cb6-40ae-b2f2-b5a7d91ad175
        Location: http://192.168.1.108:45279/upnp/dev/57a9475f-4cb6-40ae-b2f2-b5a7d91ad175/desc
        Manufacturer: GTVBox
        Model name: Vimu Player
Chromecast devices found : 2
    Device #0: Office TV
        Model name: sti6140d360
    Device #1: Moms bedroom
Hi @hifime,
I will try to reproduce this behavior as soon as possible.
Hi @hifime,
I have not been able to reproduce your issue. Do you have this, whatever the plugins you are using?
I figured out the specifics of this bug. It happens with playlists created in Tidal and not with, for example, local tracks. Steps to reproduce:
  1. In Tidal app for Mac, pick any song, then use … menu to go to track radio.
  2. In track radio, use … menu to add to playlist. Create new playlist. (Note: I need to do this because track/artist radio isn’t supported in Audirvana)
  3. In audirvana, add any plug in, e.g., Effects - Apple AUGraphicsEQ. Enable real time control and use new AU hosting API
  4. In audirvana, find playlist created in 2) under My Music > My Playlists. (You may need to restart audirvana.) Play a track. You’ll see that the focus moves away from the main window, even after you’ve moved the plugin window away from the main window.
hope this helps
I think I see what’s happening. It’s not local vs Tidal tracks; it’s actually the change in sampling rate. When switching between tracks with different spl rates, the plugin window is closed then reopened, moving the focus away from the main window.
Notes:
  1. by “switching between tracks”, I mean hovering the mouse over the track then clicking the play button that overlays the track thumbnail icon.
  2. Earlier, I misattributed this behavior to local vs tidal playlist because my local tracks are pretty uniform in spl rate, but I can reproduce the behavior simply by finding a track with different spl rate.
  3. Even with the main window not focused, clicking once on other parts of the main window UI, such as next / prev / track bar / volume bar still works. It’s only switching tracks (see note 1) that requires clicking twice.
Can you please screen record the issue and send the video at [email protected]?
