I get a loud âpopâ between songs in kernel mode. Doesnât happen using ASIO.
Update to 1.5.7 yesterday. Noise pops between songs keep coming. Using Kernel Streaming and upsampling to PCM 24/192.
bump.
@Antoine ?
Decrease the buffer to 500Mb (. 5Gb) and the problem goes away.
Is a computer problem
What can be the problem with the pc?
0.5 GB doesnât help
Hello i have the same problem in Kernel mode ! I cant use this mode anymore because of the noise at the end of each track. Donât want to damage my new speakers so i use wasapi or Asio.
When will it be fixed ?
Philippe
Long time problem, still existing. Things got better. However, seems hard to resolve. Especially, when it has upsampling on.
I am still getting it also using Kernel Streaming. It does seem to be quieter now but it still does it. I dont use upsampling. I have it plugged into a Chord Qutest via USB.
I have the same problem, some albums have it more than others.
No upsampling, via USB.
I posted a response in another thread on this subject so in case you missed that I have found that if the volume control in Audirvana is turned on (but not necessary to use it - set to 0.0db) this problem goes away.
