Bonjour, Il y a une semaine j’ai acheter Oudirvana Studio et la connection UPnP KEF bureau marcher bien.
Depuis 3 jour je ne peut plu me connecter.
Merci de votre aide
Audirvana Studio 2.0.0 (20000)
Windows 10 (19044) with 16GB physical RAM
Connected account of : Eric JOUENARD
AUTO: S:\1 - Musique - Flac
Library database path: C:\Users\ARMEN\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 2a01:cb00:dfa:5100:f68:4e46:ba57:f24c on port 61685
Active method: UPnP
Preferred device: [UPnP] KEF Bureau Model UID:KEF LS50 Wireless II UID:uuid:8b993943-6892-44ed-9e2b-87bbcfa6ef6c
Selected device:Bureau
Manufacturer: KEF
Model name: LS50 Wireless II
Model UID: KEF LS50 Wireless II
UID: uuid:8b993943-6892-44ed-9e2b-87bbcfa6ef6c
UPnP device at http://192.168.1.10:44717/8b993943-6892-44ed-9e2b-87bbcfa6ef6c.xml
8 available sample rates up to 5644800Hz
5644800
Volume control: Yes
DSD capability: Raw DSD (MSB)
UPnP set capabilities
Maximum PCM bitdepth set: 24
Maximum DSD rate set: DSD128
Avoid RAW PCM streams: No
http-get::text/xml:dlna.org_pn=didl_s
http-get::audio/vnd.dlna.adts:dlna.org_pn=heaacv2_l2_320
http-get::audio/x-ms-wma:dlna.org_pn=wmafull
http-get::audio/x-ms-wma:dlna.org_pn=wmabase
http-get::audio/3gpp:dlna.org_pn=heaacv2_l2_320
http-get::audio/mp4:dlna.org_pn=heaacv2_l2_320
http-get::audio/l16;rate=48000;channels=1:dlna.org_pn=lpcm
http-get::audio/l16;rate=48000;channels=2:dlna.org_pn=lpcm
http-get::audio/l16;rate=44100;channels=1:dlna.org_pn=lpcm
http-get::audio/l16;rate=44100;channels=2:dlna.org_pn=lpcm
http-get::audio/mpeg:dlna.org_pn=mp3
rtsp-rtp-udp::text/xml:dlna.org_pn=didl_s
rtsp-rtp-udp::audio/vnd.dlna.adts:dlna.org_pn=heaacv2_l2_320
rtsp-rtp-udp::audio/x-ms-wma:dlna.org_pn=wmafull
rtsp-rtp-udp::audio/x-ms-wma:dlna.org_pn=wmabase
rtsp-rtp-udp::audio/3gpp:dlna.org_pn=heaacv2_l2_320
rtsp-rtp-udp::audio/mp4:dlna.org_pn=heaacv2_l2_320
rtsp-rtp-udp::audio/l16;rate=48000;channels=1:dlna.org_pn=lpcm
rtsp-rtp-udp::audio/l16;rate=48000;channels=2:dlna.org_pn=lpcm
rtsp-rtp-udp::audio/l16;rate=44100;channels=1:dlna.org_pn=lpcm
rtsp-rtp-udp::audio/l16;rate=44100;channels=2:dlna.org_pn=lpcm
rtsp-rtp-udp::audio/mpeg:dlna.org_pn=mp3
http-get::audio/x-wav:
http-get::audio/x-m4a:
http-get::audio/ogg:
http-get::audio/x-flac:
http-get::audio/wave:
http-get::audio/x-dsf:
http-get::audio/wav:
http-get::audio/m4a:
http-get::text/xml:
http-get::audio/x-dff:
http-get::audio/aac:
http-get::audio/flac:
http-get::application/ogg:
http-get::audio/vorbis:
http-get::audio/x-aiff:
http-get::audio/aiff:
rtsp-rtp-udp::audio/x-wav:
rtsp-rtp-udp::audio/x-m4a:
rtsp-rtp-udp::audio/ogg:
rtsp-rtp-udp::audio/x-flac:
rtsp-rtp-udp::audio/wave:
rtsp-rtp-udp::audio/x-dsf:
rtsp-rtp-udp::audio/wav:
rtsp-rtp-udp::audio/m4a:
rtsp-rtp-udp::audio/x-dff:
rtsp-rtp-udp::audio/aac:
rtsp-rtp-udp::audio/flac:
rtsp-rtp-udp::audio/vorbis:
rtsp-rtp-udp::audio/x-aiff:
rtsp-rtp-udp::audio/aiff:
DLNA 1.5: Yes
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: dB
NrTracks: 0
MediaDuration: 0:00:00
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
Current transport actions:
<?xml version="1.0"?> 1 0 QPlay:2.1 urn:schemas-upnp-org:device:MediaRenderer:1 Bureau KEF http://www.kef.com/ LS50 Wireless II LS50 Wireless II SP4025 http://www.kef.com/ 8baee744-aeed-4122-b518-7e3eb1ae1478 uuid:8b993943-6892-44ed-9e2b-87bbcfa6ef6c image/png 120 120 24 /LibRygelRenderer-120x120x24.png image/png 48 48 24 /LibRygelRenderer-48x48x24.png image/jpeg 120 120 24 /LibRygelRenderer-120x120x24.jpg image/jpeg 48 48 24 /LibRygelRenderer-48x48x24.jpg urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /xml/ConnectionManager.xml /Control/LibRygelRenderer/RygelSinkConnectionManager /Event/LibRygelRenderer/RygelSinkConnectionManager urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /xml/AVTransport2.xml /Control/LibRygelRenderer/RygelAVTransport /Event/LibRygelRenderer/RygelAVTransport urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /xml/RenderingControl2.xml /Control/LibRygelRenderer/RygelRenderingControl /Event/LibRygelRenderer/RygelRenderingControl urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /xml/QPlayDescription.xml /Control/LibRygelRenderer/QPlay /Event/LibRygelRenderer/QPlay http://192.168.1.10:80/ DMR-1.51Current device RootDevice description:
<?xml version="1.0"?> 1 0 QPlay:2.1 urn:schemas-upnp-org:device:MediaRenderer:1 Bureau KEF http://www.kef.com/ LS50 Wireless II LS50 Wireless II SP4025 http://www.kef.com/ 8baee744-aeed-4122-b518-7e3eb1ae1478 uuid:8b993943-6892-44ed-9e2b-87bbcfa6ef6c image/png 120 120 24 /LibRygelRenderer-120x120x24.png image/png 48 48 24 /LibRygelRenderer-48x48x24.png image/jpeg 120 120 24 /LibRygelRenderer-120x120x24.jpg image/jpeg 48 48 24 /LibRygelRenderer-48x48x24.jpg urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /xml/ConnectionManager.xml /Control/LibRygelRenderer/RygelSinkConnectionManager /Event/LibRygelRenderer/RygelSinkConnectionManager urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /xml/AVTransport2.xml /Control/LibRygelRenderer/RygelAVTransport /Event/LibRygelRenderer/RygelAVTransport urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /xml/RenderingControl2.xml /Control/LibRygelRenderer/RygelRenderingControl /Event/LibRygelRenderer/RygelRenderingControl urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /xml/QPlayDescription.xml /Control/LibRygelRenderer/QPlay /Event/LibRygelRenderer/QPlay http://192.168.1.10:80/ DMR-1.51UPnP devices found : 6
Device #0: Marantz ND8006
UID: uuid:6ee38d77-dca1-18ba-0080-0005cd9aee5e
Location: http://192.168.1.22:60006/upnp/desc/aios_device/aios_device.xml
Manufacturer: Marantz
Model name: Marantz ND8006
Device #1: Bureau
Location: http://192.168.1.10:44717/8b993943-6892-44ed-9e2b-87bbcfa6ef6c.xml
Manufacturer: KEF
Device #2: Marantz ND8006
UID: uuid:5e5ea8ab-1bc8-13fb-0080-0005cd9aee5e
Device #3: Marantz ND8006
UID: uuid:35fb633e-9520-120b-0080-0005cd9aee5e
Device #4: Marantz ND8006
UID: uuid:c511117c-bb91-7354-d9d4-4046109df73a
Device #5: Marantz ND8006
UID: uuid:e864d384-a676-ad15-fcbd-af774cbe73ae
Max. memory for audio buffers: 13358MB
Local Audio Engine: WASAPI
Local devices found : 3
Device #0: PLX2483H (NVIDIA High Definition Audio)
Manufacturer: NVIDIA
Model UID: HDAUDIO\FUNC_01&VEN_10DE&DEV_009E&SUBSYS_10438825&REV_1001
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{ca699dea-3f12-4669-a244-a87327ee1162}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Realtek Digital Output (Realtek High Definition Audio)
Manufacturer: Realtek
Model UID: HDAUDIO\FUNC_01&VEN_10EC&DEV_1168&SUBSYS_10438724&REV_1000
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{f36161b2-648f-426f-a608-16462edce2a2}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #2: Haut-parleurs (Realtek High Definition Audio)
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{0cd5a0a6-c383-4021-a744-c7ccfd667ec9}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Chromecast devices found : 2
Device #0: SHIELD
ID: DnsSd#SHIELD-Android-TV-91a2ec5d905f947e7cf34c2129fa8fc4._googlecast._tcp.local#0
Model name: SHIELD Android TV
Device #1: Bureau
