Le voici:
macOS 10.13.6 with 8192MB RAM
Registered to Marco XXX
iZotope SRC not in use iZotope SRC filter parameters
Steepness = 150
Filter max length = 500000
Cut-Off (x Nyquist) = 100%
Anti-aliasing = 200
Phase = 100%
AUTO: /Volumes/Multimedia/
Library database path: /Users/marcogasparini/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
TIDAL: Connected as PREMIUM
Max. memory for audio buffers: 1022MB
Uniti Atom HE Bureau
Model UID:Naim Audio Uniti Atom HE Bureau
UID:uuid:a60fe8d0-b3b4-4ba7-bf80-f49ca867639d
ID 0xce NoMachine Audio Adapter Manufacturer:Soundflower - ma++ ingalls for Cycling '74
Model UID:com_nomachine_driver_nxauDevice:nxaudio UID:com_nomachine_driver_nxauEngine:0
Stream ID 0xcf 2 channels starting at 1
6 virtual formats:
6 physical formats
2 ch Mixable linear PCM Interleaved 32 big endian Signed Integer 192kHz
2 ch Mixable linear PCM Interleaved 32 big endian Signed Integer 176.4kHz
2 ch Mixable linear PCM Interleaved 32 big endian Signed Integer 96kHz
2 ch Mixable linear PCM Interleaved 32 big endian Signed Integer 88.2kHz
2 ch Mixable linear PCM Interleaved 32 big endian Signed Integer 48kHz
2 ch Mixable linear PCM Interleaved 32 big endian Signed Integer 44.1kHz
Local devices found : 6
Device #0: ID 0xe3 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:3 UID: AppleHDAEngineOutput:8,0,1,2:0
Device #1: ID 0x28 hiFaceTWO UAC2 Manufacturer: M2Tech Model UID: hiFaceTWO UAC2:249C:930B UID: AppleUSBAudioEngine:M2Tech:hiFaceTWO UAC2:24400000:1
Device #2: ID 0xc3 Soundflower (2ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:0
Device #3: ID 0x3c Soundflower (64ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:1
Device #4: ID 0xce NoMachine Audio Adapter Manufacturer: Soundflower - ma++ ingalls for Cycling '74 Model UID: com_nomachine_driver_nxauDevice:nxaudio UID: com_nomachine_driver_nxauEngine:0
Device #5: ID 0x31 NoMachine Microphone Adapter Manufacturer: Soundflower - ma++ ingalls for Cycling '74 Model UID: com_nomachine_driver_nxauDevice:nxaudio UID: com_nomachine_driver_nxauEngine:1
UPnP devices found : 1
Device #0: ID 0x0 Mu-so Salon UID: uuid:5F9EC1B3-ED59-79BB-4530-E8C74F026515 Location: http://192.168.1.118:8080/description.xml
