Bonjour Damien,
aujourd’hui lecture impossible en mode UPNP sur Cambridge CXNV2 ausi bien pour Tidal que pour les fichiers du NAS. Le fichier ne se charge pas donc aucune lecture.
Voici le debug info
Cordialement
Audirvana 3.5.44
AUTO: Y:
Library database path: C:\Users\jean louis\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Preferred device: Cambridge CXN V2 Model UID:Cambridge Audio Cambridge CXN V2 UID:uuid:3b4f8ca8-6d9e-4ec4-bd08-962c531955ab
UPnP device at http://192.168.1.37:8050/3b4f8ca8-6d9e-4ec4-bd08-962c531955ab/description.xml
Cambridge CXN V2 Manufacturer:Cambridge Audio
Volume control: No
DSD capability: Raw DSD (MSB)
http-get::audio/x-ms-wma:DLNA.ORG_PN=WMALSL
http-get::audio/mpeg:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/aac:
http-get::audio/wave:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/aiff:
http-get::audio/x-aiff:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/ation/ogg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/x-vorbis:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/:*
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
2 ch DSD 8bit little endian in 8bit chunk 2822.4kHz
CurrentTransportState: TRANSITIONING
NrTracks: 1
MediaDuration: 0:00:00
CurrentURI:
CurrentURIMetadata: NOT_IMPLEMENTED
nextURI:
PlayMedium: NONE
<?xml version="1.0"?> 1 0 TransportState string STOPPED PAUSED_PLAYBACK PLAYING TRANSITIONING STOPPED TransportStatus string OK PlaybackStorageMedium string NONE RecordStorageMedium string NOT_IMPLEMENTED PossiblePlaybackStorageMedia string NETWORK PossibleRecordStorageMedia string NOT_IMPLEMENTED CurrentPlayMode string NORMAL NORMAL TransportPlaySpeed string 1 1 RecordMediumWriteStatus string NOT_IMPLEMENTED CurrentRecordQualityMode string NOT_IMPLEMENTED PossibleRecordQualityModes string NOT_IMPLEMENTED NumberOfTracks ui4 0 CurrentTrack ui4 0 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 CurrentTransportActions string LastChange string A_ARG_TYPE_SeekMode string TRACK_NR REL_TIME ABS_TIME A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4 SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActionsCurrent device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 Cambridge CXN V2 Cambridge Audio http://www.cambridgeaudio.com/ CXNv2 3475 uuid:3b4f8ca8-6d9e-4ec4-bd08-962c531955ab 002024f8 image/png 48 48 8 /3b4f8ca8-6d9e-4ec4-bd08-962c531955ab/CA-roundal-48x48.png image/jpeg 48 48 24 /3b4f8ca8-6d9e-4ec4-bd08-962c531955ab/CA-roundal-48x48.jpg image/png 120 120 8 /3b4f8ca8-6d9e-4ec4-bd08-962c531955ab/CA-roundal-120x120.png image/jpeg 120 120 24 /3b4f8ca8-6d9e-4ec4-bd08-962c531955ab/CA-roundal-120x120.jpg urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /3b4f8ca8-6d9e-4ec4-bd08-962c531955ab/RenderingControl/RenderingControl1.xml /3b4f8ca8-6d9e-4ec4-bd08-962c531955ab/RenderingControl/invoke /3b4f8ca8-6d9e-4ec4-bd08-962c531955ab/RenderingControl/event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /3b4f8ca8-6d9e-4ec4-bd08-962c531955ab/ConnectionManager/ConnectionManager1.xml /3b4f8ca8-6d9e-4ec4-bd08-962c531955ab/ConnectionManager/invoke /3b4f8ca8-6d9e-4ec4-bd08-962c531955ab/ConnectionManager/event urn:schemas-upnp-org:service:ContentDirectory:1 urn:upnp-org:serviceId:ContentDirectory /3b4f8ca8-6d9e-4ec4-bd08-962c531955ab/ContentDirectory/ContentDirectory1.xml /3b4f8ca8-6d9e-4ec4-bd08-962c531955ab/ContentDirectory/invoke /3b4f8ca8-6d9e-4ec4-bd08-962c531955ab/ContentDirectory/event urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /3b4f8ca8-6d9e-4ec4-bd08-962c531955ab/AVTransport/AVTransport1.xml /3b4f8ca8-6d9e-4ec4-bd08-962c531955ab/AVTransport/invoke /3b4f8ca8-6d9e-4ec4-bd08-962c531955ab/AVTransport/event urn:UuVol-com:service:UuVolControl:5 urn:UuVol-com:serviceId:UuVolControl /3b4f8ca8-6d9e-4ec4-bd08-962c531955ab/RecivaRadio/RecivaRadio.xml /3b4f8ca8-6d9e-4ec4-bd08-962c531955ab/RecivaRadio/invoke /3b4f8ca8-6d9e-4ec4-bd08-962c531955ab/RecivaRadio/event urn:UuVol-com:service:PlaylistExtension:1 urn:UuVol-com:serviceId:PlaylistExtension /3b4f8ca8-6d9e-4ec4-bd08-962c531955ab/UuPlaylist/Playlist.xml /3b4f8ca8-6d9e-4ec4-bd08-962c531955ab/UuPlaylist/invoke /3b4f8ca8-6d9e-4ec4-bd08-962c531955ab/UuPlaylist/event urn:UuVol-com:service:UuVolSimpleRemote:1 urn:UuVol-com:serviceId:UuVolSimpleRemote /3b4f8ca8-6d9e-4ec4-bd08-962c531955ab/RecivaSimpleRemote/RecivaSimpleRemote.xml /3b4f8ca8-6d9e-4ec4-bd08-962c531955ab/RecivaSimpleRemote/invoke /3b4f8ca8-6d9e-4ec4-bd08-962c531955ab/RecivaSimpleRemote/event urn:UuVol-com:service:StreamMagic6:1 urn:UuVol-com:serviceId:StreamMagic6 /3b4f8ca8-6d9e-4ec4-bd08-962c531955ab/StreamMagic6/StreamMagic6.xml /3b4f8ca8-6d9e-4ec4-bd08-962c531955ab/StreamMagic6/invoke /3b4f8ca8-6d9e-4ec4-bd08-962c531955ab/StreamMagic6/event urn:UuVol-com:service:SMSearch:1 urn:UuVol-com:serviceId:SMSearch /3b4f8ca8-6d9e-4ec4-bd08-962c531955ab/SMSearch/SMSearch.xml /3b4f8ca8-6d9e-4ec4-bd08-962c531955ab/SMSearch/invoke /3b4f8ca8-6d9e-4ec4-bd08-962c531955ab/SMSearch/event DMR-1.50 M-DMP-1.50UPnP devices found : 4
Device #0Cambridge CXN V2 UID: uuid:3b4f8ca8-6d9e-4ec4-bd08-962c531955ab Location: http://192.168.1.37:8050/3b4f8ca8-6d9e-4ec4-bd08-962c531955ab/description.xml
Device #1panasonic ub-9000 UID: uuid:4D454930-0100-1000-8000-FFFFFFFFFFFF Location: http://192.168.1.23:60606/FFFFFFFFFFFF/Server0/ddd
Device #2BRAVIA KDL-55HX920 UID: uuid:00000000-0000-1010-8000-00A096CA15B6 Location: http://192.168.1.27:52323/dmr.xml
Device #3Cambridge CXN V2 (DLNA) UID: uuid:85fdc4a2-a1a4-0ad3-ffff-ffffac7806b1 Location: http://192.168.1.26:49976/dev/85fdc4a2-a1a4-0ad3-ffff-ffffac7806b1/desc.xml
Max. memory for audio buffers: 2602MB
Local Audio Engine:WASAPI
Device #0: Haut-parleurs (Technologie Intel® Smart Sound) Manufacturer: Model UID: Haut-parleurs (Technologie Intel® Smart Sound) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{716e60ab-0321-404c-8cbf-aa9096698635}#{e6327cad-dcec-4949-ae8a-991e976a79d2}ecture
