Bonjour Damien,
Le problème se produit à partir de fichier en local hébergés sur le mac.
ci dessous le debug info pendant la lecture d’un fichier 24-192kHz
Audirvana Mac Version 3.5.30 (3560)
macOS 10.15.3 with 16384MB RAM
Sync list: 4 folders
AUTO: /Users/herve/Music/Deezloader
AUTO: /Users/herve/Music/FLAC
AUTO: /Users/herve/Music/SACD
AUTO: /Users/herve/Music/iTunes/iTunes Media
Library database path: /Users/herve/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Qobuz: Connected as Qobuz Premium
TIDAL: Connected as FREE
Preferred device: Stream XA Model UID:Cyrus Audio Ltd Stream XA UID:uuid:5F9EC1B3-ED59-79BB-4530-0011F6A93BA3
Currently playing to UPnP device at 24 bits 192kHz
UPnP device at http://192.168.1.29:8080/description.xml
ID 0x0 Stream XA Manufacturer:Cyrus Audio Ltd
Volume control: No
http-get::audio/L16;rate=96000;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L16;rate=96000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L16;rate=88200;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L16;rate=88200;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=44100;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=48000;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=96000;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=96000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=88200;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=88200;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/wav:*
http-get::audio/x-mpegurl:
http-get::application/ogg:
http-get::audio/mp4:
http-get::audio/x-flac:
http-wavetunes::audio/x-ms-wma:
http-get::audio/x-aiff:
http-get::audio/x-m4a:
DLNA 1.5: No
Gapless playback: Yes
Can play native DSD: No
12 virtual formats:
0 physical formats
NrTracks: 1
MediaDuration: 0:03:10
CurrentURI: http://192.168.1.33:49152/audirvana/audio_1_3.wav
CurrentURIMetadata: dc:titleThe Sound of Silence (Overdubbed Version)</dc:title>upnp:artistSimon & Garfunkel</upnp:artist>upnp:albumSounds Of Silence</upnp:album>upnp:albumArtURIhttp://192.168.1.33:49152/audirvana/artwork_1_4.jpg</upnp:albumArtURI>http://192.168.1.33:49152/audirvana/audio_1_3.wav
nextURI: http://192.168.1.33:49152/audirvana/audio_0_4.wav
nextURIMetadata: dc:titleLeaves That Are Green</dc:title>upnp:artistSimon & Garfunkel</upnp:artist>upnp:albumSounds Of Silence</upnp:album>upnp:albumArtURIhttp://192.168.1.33:49152/audirvana/artwork_0_5.jpg</upnp:albumArtURI>http://192.168.1.33:49152/audirvana/audio_0_4.wav
PlayMedium: NETWORK
<?xml version="1.0"?>
1
0
SetAVTransportURI
InstanceID
in
A_ARG_TYPE_InstanceID
CurrentURI
in
AVTransportURI
CurrentURIMetaData
in
AVTransportURIMetaData
SetNextAVTransportURI
InstanceID
in
NextURI
in
NextAVTransportURI
NextURIMetaData
in
NextAVTransportURIMetaData
GetMediaInfo
InstanceID
in
NrTracks
out
NumberOfTracks
MediaDuration
out
CurrentMediaDuration
CurrentURI
out
AVTransportURI
CurrentURIMetaData
out
NextURI
out
NextAVTransportURI
NextURIMetaData
out
PlayMedium
out
PlaybackStorageMedium
RecordMedium
out
RecordStorageMedium
WriteStatus
out
RecordMediumWriteStatus
GetTransportInfo
InstanceID
in
CurrentTransportState
out
TransportState
out
TransportStatus
CurrentSpeed
out
TransportPlaySpeed
GetPositionInfo
InstanceID
in
Track
out
CurrentTrack
TrackDuration
out
CurrentTrackDuration
TrackMetaData
out
CurrentTrackMetaData
TrackURI
out
CurrentTrackURI
RelTime
out
RelativeTimePosition
AbsTime
out
AbsoluteTimePosition
RelCount
out
RelativeCounterPosition
AbsCount
out
AbsoluteCounterPosition
GetDeviceCapabilities
InstanceID
in
PlayMedia
out
PossiblePlaybackStorageMedia
RecMedia
out
PossibleRecordStorageMedia
RecQualityModes
out
PossibleRecordQualityModes
GetTransportSettings
InstanceID
in
PlayMode
out
CurrentPlayMode
RecQualityMode
out
CurrentRecordQualityMode
Stop
InstanceID
in
Play
InstanceID
in
Speed
in
TransportPlaySpeed
Pause
InstanceID
in
Seek
InstanceID
in
Unit
in
A_ARG_TYPE_SeekMode
Target
in
A_ARG_TYPE_SeekTarget
Next
InstanceID
in
Previous
InstanceID
in
SetPlayMode
InstanceID
in
NewPlayMode
in
CurrentPlayMode
GetCurrentTransportActions
InstanceID
in
Actions
out
TransportState
string
STOPPED
PLAYING
PAUSED_PLAYBACK
TRANSITIONING
NO_MEDIA_PRESENT
TransportStatus
string
OK
ERROR_OCCURRED
string
RecordStorageMedium
string
NOT_IMPLEMENTED
string
string
CurrentPlayMode
string
NORMAL
NORMAL
SHUFFLE
REPEAT_ONE
REPEAT_ALL
TransportPlaySpeed
string
1
string
NOT_IMPLEMENTED
string
NOT_IMPLEMENTED
string
NumberOfTracks
ui4
0
1
CurrentTrack
ui4
0
1
1
string
string
string
CurrentTrackURI
string
AVTransportURI
string
string
NextAVTransportURI
string
string
string
string
i4
i4
string
LastChange
string
A_ARG_TYPE_SeekMode
string
TRACK_NR
string
ui4
1
0
Stream XA
Cyrus Audio Ltd
http://www.cyrusaudio.com
Networked Audio Player
Stream XA
1.0
http://www.cyrusaudio.com/
0011F6A93BA3
123810928305556upc
/RenderingControl/desc.xml
/RenderingControl/ctrl
/RenderingControl/evt
/ConnectionManager/desc.xml
/ConnectionManager/ctrl
/ConnectionManager/evt
/AVTransport/desc.xml
/AVTransport/ctrl
/AVTransport/evt
urn:schemas-dm-holdings-com:service:X_HtmlPageHandler:1
urn:schemas-dm-holdings-com:serviceId:X_HtmlPage
/HtmlPageHandler/desc.xml
/HtmlPageHandler/ctrl
/HtmlPageHandler/evt
http://192.168.1.29:80/index.asp
urn:rhapsody-real-com:device-id-1-0:rdk_dev_2:0011F6A93BA3
UPnP devices found : 2
Device #0: ID 0x0 Stream XA UID: uuid:5F9EC1B3-ED59-79BB-4530-0011F6A93BA3 Location: http://192.168.1.29:8080/description.xml
Device #1: ID 0x0 Décodeur TV UHD UID: uuid:00ababad-7947-1048-8a00-84a06e34ad0a Location: http://192.168.1.16:42300/description.xml
Device #0: ID 0x31 Sortie intégrée Manufacturer: Apple Inc. Model UID: AppleHDA:16 UID: AppleHDAEngineOutput:1F,3,0,1,1:0
