Once I select Tidal in the left hand menu, to listen to tidal, the left side menu ONLY has tidal on it. I can’t return to the usual menu. I mu
st be missing something fairly obvious.
Can someone point me in the right direction? Thank you.
Hi @Gairth,
Can you send a screenshot of what you see?
Here are two photos fromy remote device.
The first is after i switch to tidal, the second, after i press at the blue menu icon at bottom left, where i usually get the audirvana menu.
of course my phone reversed the order of rhe 2 images.
For whatever reason after 2 trys the photo does NOT show the blue menu icon that on my screen apoears directly below where you see the king fm radio station ( almost bottom left)
If i can get a better image of this i will send it as a reply to your email
Thank you for your quick response.
Hi @Gairth,
If I understand correctly, when you are in this stage and you try again to open the menu by tapping on the bottom left side of your screen, it does not work, right?
