I’m still using the legacy, non-subscription version on my old Toshiba laptop (upgraded to Windows 10). Will soon be getting a new Windows 11 laptop, and wonder if I can continue using the same legacy Audirvana? If possible, what is the procedure? Thanks.
Hi,
I do not see any problem with that procedure. If the legacy version works on W11 (And I guess it works), then you will have to install it and enter your validation code. Maybe you will need to deactivate the license on your old laptop before moving to the new one.
Eric
