7 Go alloués à Origin (sur 8) avant j’avais 4 mais aucun changement.
Le DD ne dort pas et quand bien même la piste est déjà chargée en RAM non ?
Audirvana Origin 2.5.7 (20507)
macOS 13.6.1 with 8GB physical RAM
Connected account of :
Replay Gain: by track
AUTO: /Volumes/Zik_Klone/Music
Library database path: /Users/monnom/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 49154
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
XMOS STR USB HI-RES AUDIO
Model UID:STR USB Hi-Res Audio:20B1:308F
UID:AppleUSBAudioEngine:XMOS:STR USB Hi-Res Audio:1110000:1
Hog Mode is on
Selected device:STR USB Hi-Res Audio
Manufacturer: XMOS
Model name: XMOS STR USB Hi-Res Audio
Model UID: STR USB Hi-Res Audio:20B1:308F
UID: AppleUSBAudioEngine:XMOS:STR USB Hi-Res Audio:1120000:1
USB Vendor ID: 0x20b1
USB Product ID: 0x308f
ID 0x5b
Max volume alert: Disabled
Stream ID 0x5c 2 channels starting at 1
24 virtual formats:
32 physical formats
Device #0: ID 0x5b STR USB Hi-Res Audio
Manufacturer: XMOS
Device #1: ID 0x43 Haut-parleurs MacBook Air
Model UID: Speaker
UID: BuiltInSpeakerDevice
Model name: Apple Inc. Haut-parleurs MacBook Air
Chromecast devices found : 1
Device #0: SONY KD-77AG9
Model name: BRAVIA 4K UR2
