Libary database path
Hi Damien, I have another problem. The Library Database path is not displayed in the Windows Explorer
Hello everyone, yes it’s the same for me. I put, in French, screenshots here
Hi Damien, I created a playlist in Audirvana on the PC and then exported it to a folder. Then I deleted the playlist in Audirvana and tried to import the externally saved playlist. That doesn’t work either.
