Hi there,
I have an issue with audirvana library. I have music on a disk attached to Qnap NAS via USB3 cable. Audirvana in Windows ddoes nort recognize it.
When I add folders that are on NAS disk ot works well.
Moreover some of dsf files (DSD256) are not seen by Audirvana in Wndows.
The thing is that there are no isues like this on MAC.
Regards
Szymon
sure I can. Disk is mapped using smb. no matter whether I add it via network or as mapped drive it scans few files and stops. The scan process is shown but it does not in reality work. I have tried on 2 different computers and the result is the same. I have also switched drive to another USB port in NAS. No results. As I have already written. The same problem does not exist whyile using Mac with the same settings.
Can you map the shared folder to a drive letter?
Can you give us an example of the path of one of the folder you try to sync?
