Because the super company Apple has just changed the SMB protocol with Catalaina, I can no longer access my router without an FTP program. And thus also not on my library. And I can’t find a way to enter the path manually.
Unfortunately I don’t know much about the terminal
Audirvana team… Please update software
The problem is the access to the network drive. It’s on a Fritzbox Cable 6951, which doesn’t support SMB3. Apple introduced that with Catalina. But I hadn’t thought of that before. So I’m very annoyed with Apple. To many problems with that company !!!
Here is also AVM partially to blame for still using a very old SMB implementation that is considered insecure. Not much you can do here other than attaching the external drive directly to the Mac.
You might want to consider a cheap NAS as alternative to sharing files through the Fritzbox.
So, i have installed a “Labor” Version with SMB3 support. But it does’t work. Also, the Fritz.NAS is not shown in the Apple finder. I get crazy with all that f****d things
