I have been using Audirvana for over a year now, currently ver. 3.5.46 on an old iMac running OS X El Capitan 10.11.6. It was working fine yesterday, but now it won’t see my local library of music files. I have tried rebuilding the database option and I get “Unknown error”. Same error with ‘Rebuild index’. If I try adding my music folder as a monitored folder I get " Fatal error adding folder to watch list".
I tested my Tidal connection to see if that was working and it played Tidal selections just fine. I tried rebooting the iMac and now the Tidal songs play back very distorted. Any suggestions?
- update - did a reboot and shut off the DAC for awhile and now Tidal is playing fine. Did a Disk Utility test of the drive holding the music files and it checks out ok.
