Library on external disk fails loading
Hello, I am a week into my free trial period and I am disappointed. Audirvana Origin only loads a small portion of the music files on my external drive.
I tried deleting everything and starting all over. Other files were loaded, but never my whole library. Any idea what I am doing wrong?
(Macbook Air, OS Ventura, Scandisk SSD 2TB)
Hi @filletk,
Hi, thanks for the fast response. Here is the Debug Info:
Audirvana Origin 2.5.2 (20502)
macOS 13.3.1 with 8GB physical RAM
Connected account of : Koen Fillet
AUTO: /Volumes/Extreme SSD 1/
iTunes/Music library synchronization: last synchronized on Fri Nov 10 09:47:57 2023
Library database path: /Users/koen/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 63654
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Apple Inc. Externe koptelefoon
Model UID:Codec Output
UID:BuiltInHeadphoneOutputDevice
Selected device:MacBook Air luidsprekers
Model name: Apple Inc. MacBook Air luidsprekers
Model UID: Speaker
UID: BuiltInSpeakerDevice
ID 0x7e
Stream ID 0x7f 2 channels starting at 1
4 virtual formats:
4 physical formats
Local devices found : 3
Device #0: ID 0x7e MacBook Air luidsprekers
Model UID: Speaker
Device #1: ID 0x3f Microsoft Teams Audio
Manufacturer: Microsoft Corp.
Device #2: ID 0x49 SoundTap Virtual Device
Manufacturer: NCH Software.
Model UID: SoundTapVirtualAudioDevice_ModelUID
UID: SoundTapVirtualAudioDevice_UID
Model name: NCH Software. SoundTap Virtual Device
Chromecast devices found : 1
Device #0: Hobbykamer
Model name: Chromecast HD
Ok, can you go in the Audirvāna settings and in the My account section? You will see a button ‘Start Log Session’, click on it and then click on the Sync button next to your folder path in Audirvāna Origin settings. After the sync is done, click on ‘Stop Log Session’ and then send me the log file you can find by clicking on the button ‘Open Log Folder’ at [email protected]
Done
log file send to [email protected]
It’s 2026 and I have the same exact problem. You want 150 euro for this?
Welcome…
I did open a ticket. But since I found this post and others with the same issue years ago, and it still hasn’t been resolved from the engineer’s side…I have low expectations my issue will be resolved. Fingers crossed.
Note: The DRM-protected tracks (usually files ending with .m4p), due to the copy protection mechanism, like the ones coming from Apple Music content is not supported by Audirvāna and thus are not synced by the app.
Which audio file formats are compatible with Audirvāna?
What are you talking about? I don’t have any m4p or whatever that is. They are all flacs from my own private flac collection. Audirvana is lazy engineering with absurd pricing. Thank Zeus for trials.
