Hi,
I’m having a problem launching Audirvana +, on a mac mini under macOS 10.12.6
Audirvana + is in version 3.2.8 (3139)
At each launch of the application, I have the message: “Error opening the library” and I have to create a new library.
Do you have a solution to this problem?
Cordially.
Philippe.
Bonjour,
J’ai un problème pour lancer Audirvana +, sur un mac mini sous macOS 10.12.6
Audirvana + est dans la version 3.2.8 (3139)
À chaque lancement de l’application, j’ai le message: “Erreur lors de l’ouverture de la bibliothèque” et je dois créer une nouvelle bibliothèque.
Avez-vous une solution à ce problème?
Cordialement.
Philippe.
remove database with the minus sign in A+ pref panel. now you have no music… Quit A+.
Trash All the files in that folder (that is your database of music, back it up! Or not)
Restart MAC after, then Restart A+ and had a music folder… and let it load fully before trying somthimg else go to sleep if too long
