Here is my debug information :
udirvana Mac Version 3.5.42 (3572)
Registered to Anthony Lee
AUTO: /Volumes/Server/Music Library
Library database path: /Users/anthonymanhonlee/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Integer mode: Disabled
exD USB Audio Out
Model UID:exD USB-DSD Audio:ABCD:0008
UID:AppleUSBAudioEngine:exD :exD USB-DSD Audio:DSD_DoP:1
Limit bitdepth to 24bit: ON
ID 0x30 Built-in Output Manufacturer:Apple Inc.
Model UID:AppleHDA:82 UID:AppleHDAEngineOutput:1B,0,1,1:0
Stream ID 0x31 2 channels starting at 1
4 virtual formats:
12 physical formats
Device #0: ID 0x30 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:82 UID: AppleHDAEngineOutput:1B,0,1,1:0
UPnP devices found : 1
Device #0: ID 0x0 KD-49X8500F UID: uuid:23456789-1234-1010-8000-CC988BC99749 Location: http://192.168.50.2:52323/MediaRenderer.xml
