Is there a way to name a Library?
I have my music files on 2 different external drives. I would like to create two separate Libraries, one for each drive. I would like each library titled differently in Audirvana’s interface. Is this possible?
It is not possible …
Thank you, Stefano. That’s disappointing…
… but you can create two smart playlists selecting the criteria “file location” contains “…”
Yeah, I know. I just hoped to have a visual input as to which Library I am using. No big deal, though.
Right click those playlists after and rename them whatever you want, in capital letters also If needed
Thanks, RHS. I knew that. I was wondering about renaming the Library, not Playlists (see my original post).
