Currently using Audirvana + 3.2.2. If I upgrade to Audirvana 3.5 how do I transfer my
current library from 3.2.2 to 3.5? Over the years I’ve customized my library and do not want to do that all over again.
Hello @Vrac,
You have nothing to do, you just need to uninstall Audirvana 3.2 and install 3.5 and Audirvana will use your 3.2 library.
