Licence key lost with MacBook restore from TimeMachine
Hi,
I had to re-install my MacBook from Time Machine after a crash and now I cannot access my Audirvana 3.5 anymore because I’ve lost the license key. Is there any way to recover it?
Many thanks for your help,
Olivier
If you get the error ā€˜Too many installations’ go to:
Login To My Account - Easy Remove Audirvana 3.5 Activation
And click ā€˜Reset’:
But if you completely lost/forgot your key you can send a mail to [email protected]. They will help you further.
Many thanks Andy for your quick help. I contacted support via the email address you provided, cheers for that!
