Licene Key not working - Please reset
I got a new MacBook and I followed the instructions to uninstall Audiovana from the old Mac. However on my new laptop, whenever I enter the existing license key, I get an error saying “There is no valid license available to continue execution of Audirvana”
I do have the receipt of my purchase as proof. And I had only ever installed it on one computer which as I said I uninstalled before I got my new computer, so there should not be any problem in my using this license key. Could you please check on this and let me know what to do?
Hello @XtenMan, i sent you a private message regarding this.
Yes in the private message you asked me to upgrade to a new version 3.5 by paying an extra $68. So you are misunderstanding what I am asking. I said I have a fully paid version of Audiovana and I uninstalled it form my old laptop following the directions on your website. And now I have been trying to use that license key on my new laptop since Nov 2019. It does not work.
So I need to know how to get the product that I have already paid to work. I do not need to know nor am I interested in buying or upgrading to a new product and paying your more money.
Actually I re download the older version and this time it took my license key, so the player started up now.
However I cannot add any files now. Please see attached video:
This video will illustrate the issue and hopefully you will be able to advice me what the problem might be.
Hello @XtenMan, before you choose one of your folder from your googledrive, have you make sure it was correctly synced in your Computer? I can see on the Eagle folder that you have red dot next to it so you might have a sync error.
Yes the folders are synced to my local hard drive. the Eagles folder red mark, is something I created. I marked it in red to highlight it for you. There is no red mark on the actual folder when I look at it through Finder.
Also note that all the other folders are also synced to my hard dive. Additionally, I moved one folder into my local hard drive, but still nothing
You are on Catalina?
Yes, Catalina. Ver 10.15.4
Have your tried with Audirvana 3.5? You can try it for free here: https://audirvana.com/try/
If you can’t request a 30 days trial we can give you an extra time.
Well I am not really looking to spend money and buy a new version. I just want to get my existing product to work. Does it not work with Catalina?
There is a risk about it since we do not update Audirvana 3.2 anymore, have you tried to come back to Mojave?
No I have not and will never downgrade my operating system just to run a audio player. I don’t think anyone will ever do that.
