Hello,
I recently purchased Audirvana and had to re-install. So I deleted the app and re-downloaded. I try to register it with my key but is asking me for a lic file… I dont have a lic file… I have a Key.
Help please.
Hello,
Help please.
You have currently the old version 2 installed. You need first to replace it with the version 3 trial you can download from audirvana.com.
Thanks for the help!
