I just updated Origin and now I have this line showing up in the waveform view of the Audio Scan page. Is it out of position. Should it be in the centre of the waveform?
Hi @Ric1 , do you get this, whatever track you play?
I donāt have it on my end ![]()
Which version of macOS do you have, and do you have it when you are not doing an audio scan?
OS 15.7.4 (24G517) on MacMini M1
I only occurs in the Audio Scan page.
Below is a screenshot of the waveform on the Album page.
Looks normal for meā¦
- macOS 26.3.1 (a)
- AudirvÄna Studio v3 (2.99.21)
- Display resolution: 1280 x 1024
This is occurring in ORIGIN. I havenāt changed the Macās OS, so the only difference is the newer version of ORIGIN.
I canāt tell if it is also happening on the iOS beta app because I canāt seem to āstartā the AudioScan from the App. I try and click on āstartā, but nothing happens so I canāt compare.
I was able to do the scan on my wifeās iPad (which still has the older iOS app) and noticed it does not display the waveform or volume like the Main software.
I always do the AudioScan from the main program on the MacMini.
Anybody else using ORIGIN experiencing this?
