**Hi folks, **
No luck with the StartasService SH script in my various Linux distros.
I type “sudo” in Terminal to enable root privilege, then drag across the SH script and press enter. It then shows:
Usage: /opt/audirvana/origin/setAsService.sh {enable|disable|start|stop|status} [username]
enable: install audirvanaOrigin service and enable it for autostart at system boot
if username is specified, the service will run as this user, otherwise the user audirvana will be created and used*
disable: remove audirvanaOrigin service
start: start audirvanaOrigin service
stop: stop audirvanaOrigin service
status: show audirvanaOrigin service status
Now what?! Please someone help!
Many thanks, G
