Hello at Audirvana,
i have a problem described in the title.
All is fine, Network is ok, firewall is all right.
But if i select one title, in the program or by remote, nothing is played. Only the message „Loading first title“ „Ersten Titel laden“ in German is displayed.
What can this be?
Thank you
macfloer
Are you trying to play local files, from external storage, Tidal, …?
Hello, i only want to Play the Files from my iMac. The music does not Start at all. Only the Message „loading the First Titel“ occurs.
Have you been moving the files in the folders that are part if the library?
Good Morning,
No, i have already made a complete new structure of the library, reinstalled the program, but no success.
What can i do?
What DAC do you use? Have you tried to play with the built in audio device?
Yes, of course, same result.
As DAC i use a Cambridge NQ.
Can you post the debug info here? You’ll find it in the Audirvana menu.
Ok, here it is:
macOS 10.14.6 with 32768MB RAM
Registriert nach Thomas Flöer
Per track: OFF
SW volume control: ON
AUTO: /Users/macfloer/Music/HighRes Files
iTunes/Music library synchronization: last synchronized on Sat Apr 24 10:31:31 2021
Library database path: /Users/macfloer/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Preferred device: Edge NQ Model UID:Cambridge Audio Edge NQ UID:uuid:ac21ea17-a53b-4afc-bda8-2213306e2b62
UPnP device at http://192.168.178.23:8050/ac21ea17-a53b-4afc-bda8-2213306e2b62/description.xml
ID 0x0 Edge NQ Manufacturer:Cambridge Audio
Volume control: No
DSD capability: Raw DSD (MSB)
http-get::audio/x-ms-wma:DLNA.ORG_PN=WMALSL
http-get::audio/mpeg:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/aac:
http-get::audio/wave:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/aiff:
http-get::audio/x-aiff:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/ation/ogg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/x-vorbis:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/:*
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
20 virtual formats:
0 physical formats
CurrentTransportState: TRANSITIONING
NrTracks: 0
MediaDuration: 0:00:00
CurrentURI:
CurrentURIMetadata: NOT_IMPLEMENTED
nextURI:
PlayMedium: NONE
<?xml version="1.0"?> 1 0 TransportState string STOPPED PAUSED_PLAYBACK PLAYING TRANSITIONING STOPPED TransportStatus string OK PlaybackStorageMedium string NONE RecordStorageMedium string NOT_IMPLEMENTED PossiblePlaybackStorageMedia string NETWORK PossibleRecordStorageMedia string NOT_IMPLEMENTED CurrentPlayMode string NORMAL NORMAL TransportPlaySpeed string 1 1 RecordMediumWriteStatus string NOT_IMPLEMENTED CurrentRecordQualityMode string NOT_IMPLEMENTED PossibleRecordQualityModes string NOT_IMPLEMENTED NumberOfTracks ui4 0 CurrentTrack ui4 0 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 CurrentTransportActions string LastChange string A_ARG_TYPE_SeekMode string TRACK_NR REL_TIME ABS_TIME A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4 SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActionsCurrent device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 Edge NQ Cambridge Audio http://www.cambridgeaudio.com/ Edge NQ 3467 uuid:ac21ea17-a53b-4afc-bda8-2213306e2b62 00202f9c image/png 48 48 8 /ac21ea17-a53b-4afc-bda8-2213306e2b62/CA-roundal-48x48.png image/jpeg 48 48 24 /ac21ea17-a53b-4afc-bda8-2213306e2b62/CA-roundal-48x48.jpg image/png 120 120 8 /ac21ea17-a53b-4afc-bda8-2213306e2b62/CA-roundal-120x120.png image/jpeg 120 120 24 /ac21ea17-a53b-4afc-bda8-2213306e2b62/CA-roundal-120x120.jpg urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /ac21ea17-a53b-4afc-bda8-2213306e2b62/RenderingControl/RenderingControl1.xml /ac21ea17-a53b-4afc-bda8-2213306e2b62/RenderingControl/invoke /ac21ea17-a53b-4afc-bda8-2213306e2b62/RenderingControl/event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ac21ea17-a53b-4afc-bda8-2213306e2b62/ConnectionManager/ConnectionManager1.xml /ac21ea17-a53b-4afc-bda8-2213306e2b62/ConnectionManager/invoke /ac21ea17-a53b-4afc-bda8-2213306e2b62/ConnectionManager/event urn:schemas-upnp-org:service:ContentDirectory:1 urn:upnp-org:serviceId:ContentDirectory /ac21ea17-a53b-4afc-bda8-2213306e2b62/ContentDirectory/ContentDirectory1.xml /ac21ea17-a53b-4afc-bda8-2213306e2b62/ContentDirectory/invoke /ac21ea17-a53b-4afc-bda8-2213306e2b62/ContentDirectory/event urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /ac21ea17-a53b-4afc-bda8-2213306e2b62/AVTransport/AVTransport1.xml /ac21ea17-a53b-4afc-bda8-2213306e2b62/AVTransport/invoke /ac21ea17-a53b-4afc-bda8-2213306e2b62/AVTransport/event urn:UuVol-com:service:UuVolControl:5 urn:UuVol-com:serviceId:UuVolControl /ac21ea17-a53b-4afc-bda8-2213306e2b62/RecivaRadio/RecivaRadio.xml /ac21ea17-a53b-4afc-bda8-2213306e2b62/RecivaRadio/invoke /ac21ea17-a53b-4afc-bda8-2213306e2b62/RecivaRadio/event urn:UuVol-com:service:PlaylistExtension:1 urn:UuVol-com:serviceId:PlaylistExtension /ac21ea17-a53b-4afc-bda8-2213306e2b62/UuPlaylist/Playlist.xml /ac21ea17-a53b-4afc-bda8-2213306e2b62/UuPlaylist/invoke /ac21ea17-a53b-4afc-bda8-2213306e2b62/UuPlaylist/event urn:UuVol-com:service:UuVolSimpleRemote:1 urn:UuVol-com:serviceId:UuVolSimpleRemote /ac21ea17-a53b-4afc-bda8-2213306e2b62/RecivaSimpleRemote/RecivaSimpleRemote.xml /ac21ea17-a53b-4afc-bda8-2213306e2b62/RecivaSimpleRemote/invoke /ac21ea17-a53b-4afc-bda8-2213306e2b62/RecivaSimpleRemote/event urn:UuVol-com:service:StreamMagic6:1 urn:UuVol-com:serviceId:StreamMagic6 /ac21ea17-a53b-4afc-bda8-2213306e2b62/StreamMagic6/StreamMagic6.xml /ac21ea17-a53b-4afc-bda8-2213306e2b62/StreamMagic6/invoke /ac21ea17-a53b-4afc-bda8-2213306e2b62/StreamMagic6/event urn:UuVol-com:service:SMSearch:1 urn:UuVol-com:serviceId:SMSearch /ac21ea17-a53b-4afc-bda8-2213306e2b62/SMSearch/SMSearch.xml /ac21ea17-a53b-4afc-bda8-2213306e2b62/SMSearch/invoke /ac21ea17-a53b-4afc-bda8-2213306e2b62/SMSearch/event DMR-1.50 M-DMP-1.50UPnP devices found : 3
Device #0: ID 0x0 DMS_192.168.178.22 UID: uuid:bb5e21ce-1111-11b2-f918-AC6FBB315982 Location: http://192.168.178.22:49152/description.xml
Device #1: ID 0x0 Soundbar 700 GW3 UID: uuid:8cb2bbd3-f477-4b06-e441-f51055165788 Location: http://192.168.178.29:8091/8cb2bbd3-f477-4b06-e441-f51055165788.xml
Device #2: ID 0x0 Edge NQ UID: uuid:ac21ea17-a53b-4afc-bda8-2213306e2b62 Location: http://192.168.178.23:8050/ac21ea17-a53b-4afc-bda8-2213306e2b62/description.xml
Max. memory for audio buffers: 31744MB
Device #0: ID 0x2d Ausgang (integriert) Manufacturer: Apple Inc. Model UID: AppleHDA:130 UID: AppleHDAEngineOutput:1F,3,0,1,2:0
Try to map the music folder directly using the second method.
Sorry, which second method?
Thank you!
The monitored folders method.
Sorry, that does not change anything.
Yesterday, after a restart, i had no issues. But after stopping the software and want to start again with listening music, nothing happend again. A software that sometimes works and sometimes not is not so good. I am the only user with this experience?
Thank you for your efforts!
