Hi, I have just installed Audirvana for the first time. I have local files and Tidal linked, and it displays everything fine. When playing Audirvana through the built-in speaker of my Imac, all is well. When I then select my Audiolab 6000N as the output, it says “loading first track…” and nothing happens from there on. Any idea? Thanks!
Debug info (truncated as new users may only include 5 links):
Audirvana Mac Version 3.5.41 (3571)
macOS 10.14.6 with 16384MB RAM
AUTO: /Users/mvdh/Music/iTunes
Library database path: /Users/mvdh/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
TIDAL: Connected as PREMIUM
Preferred device: Audiolab 6000N Model UID:Phorus Audiolab 6000N UID:uuid:3d62cbc4-32f8-4fbc-8618-e44cc78013c9
UPnP device at http://192.168.1.65:49152/description.xml
ID 0x0 Audiolab 6000N Manufacturer:Phorus
Volume control: No
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/mpeg:
http-get::audio/mp3:
http-get::audio/aac:
http-get::audio/ac3:
http-get::audio/x-flac:
http-get::audio/flac:
http-get::audio/x-hx-aac-adts:
http-get::audio/3gpp:
http-get::audio/mp4:
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
12 virtual formats:
0 physical formats
