I saw already numerous requests for help about above issue and with no apparant solutions offered. Having the same issue now after a few months of flawless behaviour of the software. Firewall, debug info send to support: no solution.
Someone might have an idea?
Doesn’t work anymore on Mac mini M1 and even tried it on an older iMac, gets stuck too.
Thx for input
Danny
Hello @Danny,
This message can appear for a lot of reason. When do you have this message?
Hi Damien
the message appears as soon as I try to use the application. I open it, I select the music track I want to listen to and the track never starts playing
Can you send us a copy of the “Debug Info” when you have this issue? You can get it in Audirvana Settings>General>Debug Info
here you go (as is in my old iMac now, last week I shared by mail the debug info on my Mac mini m1)
macOS 10.13.6 with 8192MB RAM
Registered to danny nijs
AUTO: /Users/Shared
iTunes/Music library synchronization: last synchronized on Sun Aug 1 23:30:40 2021
Library database path: /Users/daniel/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Preferred device: ATOLL Streamer Model UID:ATOLL Electronique ATOLL Streamer UID:uuid:15f46361-19d2-41d5-b2d2-08105cf38252
UPnP device at http://192.168.68.112:42283/15f46361-19d2-41d5-b2d2-08105cf38252.xml
ID 0x0 ATOLL Streamer Manufacturer:ATOLL Electronique
Volume control: No
DSD capability: Raw DSD (MSB)
http-get::application/ogg:
http-get::text/xml:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/ogg:
http-get::audio/mpeg:
http-get::audio/x-wav:
http-get::audio/x-m4a:
http-get::audio/aiff:
http-get::audio/vorbis:
http-get::audio/wav:
http-get::audio/m4a:
http-get::audio/x-aiff:
http-get::audio/aac:
http-get::audio/x-dsf:
http-get::audio/wave:
http-get::audio/x-dff:
rtsp-rtp-udp::audio/flac:
rtsp-rtp-udp::audio/x-flac:
rtsp-rtp-udp::audio/ogg:
rtsp-rtp-udp::audio/x-wav:
rtsp-rtp-udp::audio/x-m4a:
rtsp-rtp-udp::audio/aiff:
rtsp-rtp-udp::audio/vorbis:
rtsp-rtp-udp::audio/wav:
rtsp-rtp-udp::audio/m4a:
rtsp-rtp-udp::audio/x-aiff:
rtsp-rtp-udp::audio/aac:
rtsp-rtp-udp::audio/x-dsf:
rtsp-rtp-udp::audio/wave:
rtsp-rtp-udp::audio/x-dff:
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
14 virtual formats:
0 physical formats
NrTracks: 0
MediaDuration: 0:00:00
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
<?xml version="1.0"?> 1 0 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetMediaInfo_Ext InstanceID in A_ARG_TYPE_InstanceID CurrentType out CurrentMediaCategory NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID X_DLNA_GetBytePositionInfo InstanceID in A_ARG_TYPE_InstanceID TrackSize out X_DLNA_CurrentTrackSize RelByte out X_DLNA_RelativeBytePosition AbsByte out X_DLNA_AbsoluteBytePosition SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode TransportState string STOPPED PAUSED_PLAYBACK PAUSED_RECORDING PLAYING RECORDING TRANSITIONING NO_MEDIA_PRESENT TransportStatus string OK ERROR_OCCURRED CurrentMediaCategory string NO_MEDIA TRACK_AWARE TRACK_UNAWARE CurrentTransportActions string PlaybackStorageMedium string UNKNOWN DV MINI-DV VHS W-VHS S-VHS D-VHS VHSC VIDEO8 HI8 CD-ROM CD-DA CD-R CD-RW VIDEO-CD SACD MD-AUDIO MD-PICTURE DVD-ROM DVD-VIDEO DVD-R DVD+RW DVD-RW DVD-RAM DVD-AUDIO DAT LD HDD MICRO-MV NETWORK NONE NOT_IMPLEMENTED SD PC-CARD MMC CF BD MS HD_DVD RecordStorageMedium string UNKNOWN DV MINI-DV VHS W-VHS S-VHS D-VHS VHSC VIDEO8 HI8 CD-ROM CD-DA CD-R CD-RW VIDEO-CD SACD MD-AUDIO MD-PICTURE DVD-ROM DVD-VIDEO DVD-R DVD+RW DVD-RW DVD-RAM DVD-AUDIO DAT LD HDD MICRO-MV NETWORK NONE NOT_IMPLEMENTED SD PC-CARD MMC CF BD MS HD_DVD PossiblePlaybackStorageMedia string NONE NETWORK PossibleRecordStorageMedia string CurrentPlayMode string NORMAL REPEAT_TRACK REPEAT_ONE REPEAT_ALL NORMAL TransportPlaySpeed string 1 1 RecordMediumWriteStatus string WRITABLE PROTECTED NOT_WRITABLE UNKNOWN NOT_IMPLEMENTED CurrentRecordQualityMode string 0:EP 1:LP 2:SP 0:BASIC 1:MEDIUM 2:HIGH NOT_IMPLEMENTED PossibleRecordQualityModes string NumberOfTracks ui4 0 512 CurrentTrack ui4 0 512 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 LastChange string A_ARG_TYPE_SeekMode string ABS_TIME REL_TIME TRACK_NR ABS_COUNT REL_COUNT X_DLNA_REL_BYTE A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4 X_DLNA_RelativeBytePosition string X_DLNA_AbsoluteBytePosition string X_DLNA_CurrentTrackSize stringCurrent device RootDevice description:
<?xml version="1.0"?> 1 0 QPlay:2.1 urn:schemas-upnp-org:device:MediaRenderer:1 ATOLL Streamer ATOLL Electronique https://www.atoll-electronique.com/ ATOLL Streamer http://www.atoll-electronique.com/ 1940000347 uuid:15f46361-19d2-41d5-b2d2-08105cf38252 image/png 120 120 24 /LibRygelRenderer-120x120x24.png image/png 48 48 24 /LibRygelRenderer-48x48x24.png image/jpeg 120 120 24 /LibRygelRenderer-120x120x24.jpg image/jpeg 48 48 24 /LibRygelRenderer-48x48x24.jpg urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /xml/ConnectionManager.xml /Control/LibRygelRenderer/RygelSinkConnectionManager /Event/LibRygelRenderer/RygelSinkConnectionManager urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /xml/AVTransport2.xml /Control/LibRygelRenderer/RygelAVTransport /Event/LibRygelRenderer/RygelAVTransport urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /xml/RenderingControl2.xml /Control/LibRygelRenderer/RygelRenderingControl /Event/LibRygelRenderer/RygelRenderingControl urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /xml/QPlayDescription.xml /Control/LibRygelRenderer/QPlay /Event/LibRygelRenderer/QPlay [http://192.168.68.112:80/](http://192.168.68.112/) DMR-1.51UPnP devices found : 4
Device #0: ID 0x0 ATOLL Streamer UID: uuid:15f46361-19d2-41d5-b2d2-08105cf38252 Location: http://192.168.68.112:42283/15f46361-19d2-41d5-b2d2-08105cf38252.xml
Device #1: ID 0x0 Volumio UID: uuid:04255cb4-11f0-58db-0053-b827ebe7c6be Location: http://192.168.0.221:49152/description.xml
Device #2: ID 0x0 V UID: uuid:5206560a-306a-2e08-5a43-b827ebe7c6be Location: http://192.168.0.221:49152/description.xml
Device #3: ID 0x0 Danny_Volumio UID: uuid:ecf5d3b8-8e0e-91d8-9fa1-b827ebe7c6be Location: http://192.168.0.221:49153/description.xml
Device #0: ID 0x2e Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:90 UID: AppleHDAEngineOutput:1B,0,1,2:0
The issue appears when you are playing a Tidal track, Local track or both?
both
same thing on the Mac mini M1
Can you update to the latest version of 3.5 and try again?
upgraded, same result, still hangs with first track
Any news about this? Are you looking into a solution?
Im guessing this is happeneing when streaming with Tidal? I had the same issue and solved by changing the settings for Tidal “limit streaming quality to” option which was previously at MQA and reducing it to high. Restarted application and AMP and it worked.
