Even after completely synchronisation of the local library, nothing shows up on the local album interface.The Artist category is fully populated (with multiple entries of the same artist!) but nothing in the album category.Would appreciate any help!
Same here, bump it up
Same here! Free trial about to run out and with no local albums showing and no working remote I wonāt be taking the plunge at the moment. Think Iāll stick with 3.5.
Same⦠Based on the lack of response from tech-support here, I can make a pretty good prediction of what Iāll do after my 30 day trial.
Perhaps if we keep bumping this thread to the top of the list, someone from tech might take notice. I have a very full list of local artists but apparently absolutely none of my 3,000 local albums and associated tracks actually exist!
Actually⦠got it working. From the album view I switched the filter to artist and everything showed up right away.
There is a problem with filters and sorting. By default, something is active so that nothing or not everything is visible. After some adding and changing filters and sorting settings everything is visible. Until you go to another view and back again. then everything is gone again.
you click save for all after making choices? in sortingā¦
It doesnāt seem to be about the content of the filter or sorting. But the trigger that something changed. At least with the Qobuz filtering.
With the local, as I type this, everything seems to appear after about 1 minute.
CANāT PLAY MUSIC WITHOUT SOME VISIBILITY OF LIBRARY! Like the others having issues with Album View, I have 1724 albums and canāt even listen to anything when the Album View disappears, and I have a super fast scroll on my mouse set to the slowest speed, making music selection in Tracks view impossible. This problem with blank Album View just started up on me today.
This issue really should be addressedā¦
Absolutely. I can navigate (poor) album view, but once I play a song, I go back to a blank album list. I have to exit the program and relaunch to play something else.
All of a sudden I cannot see local albums on the local machine nor the connected remote app.
I can search and all content is available but the LOCAL Album view says no albums found.
I did notice that my system is constantly analyzing music. It never completes, no matter how long the system is up and running. It will not immediately add the new albums to the database.
Also, it is a pain in the neck to make playlist. If I do import a playlist it will not import the 1st track.
The LOCAL Albums is a big issue. It makes the system not usable.
The library got corrupt or something. I had to make a new database file. However now I canāt load the app as it says that there is NO database file and will not open.
Hello @palldat,
Can you please send a screenshot of the error?
So I created another database location and it now works.
