I’ve posted this issue before. Now that the new remote has been released, I thought I would try to use AV Studio again. The remote does work with both versions of AV, but when using Studio, the Lock Button icon changes to an unlock position when tapped, but I can only get a second or two of music to play through my audio device before Studio grabs control and disconnects my other input software (Pandora in this case via Airplay). The volume control indicator in AVS flickers as it grabs control. If I Quit AVS, all works as it’s supposed to. I have no problems with audio unit control with AV 3.5. I need some help here or will not be renewing my subscription next year.
SAME PROBLEM EXISTS !!! New release acts exactly as I described above. Is anyone reading these posts?? I can only use 3.5.5, not Studio. Please help: Thanks - Louis
Hello @Lpengue,
Please remove the line corresponding to your logged-in account to avoid displaying your email address and first name/last name publicly.
Debug info below.
I used Studio to play an album and cycle through several tracks. I then used the remote app to pause and then STOP play. The Lock icon changed to Unlock. I then went to Pandora on my mobile device and connected to the remote Audio Device that Studio was playing through using an Ethernet connection. Pandora is using an Airplay connection. Pandora connects to the Audio Device, but when I try to play music, I get a second or less of play through the Audio Device, and at the same time Studio shows the volume control bar cycle to off and full on again. Pandora is now disconnected from the Audio Device. I went through the process several times with no change. 3.5.5 fully releases the Audio Device and Pandora plays with no issues. With Studio, I have to shut down the app to regain control of the Audio Device.
Hope this helps.
Audirvana Studio 1.7.1 (10701)
macOS Version 11.6 (Build 20G165) with 32GB physical RAM
Connected account: xxxxxxxxxxx
AUTO: /Volumes/1TB MyBook/
Library database path: /Users/louisminimac/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 56411
Preferred device: B&W GROUP LTD CP-800 Model UID:B&W Group Ltd CP-800 UID:uuid:5f9ec1b3-ed59-1900-4530-d81ede20a760
UPnP device at http://192.168.1.2:8080/description.xml
ID 0x0 CP-800
Manufacturer: B&W Group Ltd
Model Name:
Model UID: B&W Group Ltd CP-800
UID: uuid:5f9ec1b3-ed59-1900-4530-d81ede20a760
Volume control: No
Avoid RAW PCM streams: No
http-get:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM
http-get:*:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get:*:audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM
http-get:*:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL
http-wavetunes::audio/x-ms-wma:
http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS
http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_320
http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO
http-get:*:audio/3gpp:DLNA.ORG_PN=AAC_ISO
http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO_320
http-get:*:audio/3gpp:DLNA.ORG_PN=AAC_ISO_320
http-get::audio/x-caf:
http-get::audio/x-aiff:
http-get::audio/aiff:
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
Volume Control: scalar
14 virtual formats:
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 44.1kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 48kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 44.1kHz finite length
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 44.1kHz finite length
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 88.2kHz finite length
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 88.2kHz finite length
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 176.4kHz finite length
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 176.4kHz finite length
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 48kHz finite length
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 48kHz finite length
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 96kHz finite length
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 96kHz finite length
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 192kHz finite length
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 192kHz finite length
0 physical formats
NrTracks: 1
MediaDuration: 0:02:13
CurrentURI: http://192.168.1.9:49152/audirvana/audioTest.pcm
CurrentURIMetadata:
dc:titletestTitle</dc:title>
nextURI:
nextURIMetadata:
PlayMedium: NETWORK
<?xml version="1.0"?>1
0
SetAVTransportURI
InstanceID
in
A_ARG_TYPE_InstanceID
CurrentURI
in
AVTransportURI
CurrentURIMetaData
in
AVTransportURIMetaData
SetNextAVTransportURI
InstanceID
in
NextURI
in
NextAVTransportURI
NextURIMetaData
in
NextAVTransportURIMetaData
GetMediaInfo
InstanceID
in
NrTracks
out
NumberOfTracks
MediaDuration
out
CurrentMediaDuration
CurrentURI
out
AVTransportURI
CurrentURIMetaData
out
NextURI
out
NextAVTransportURI
NextURIMetaData
out
PlayMedium
out
PlaybackStorageMedium
RecordMedium
out
RecordStorageMedium
WriteStatus
out
RecordMediumWriteStatus
GetTransportInfo
InstanceID
in
CurrentTransportState
out
TransportState
out
TransportStatus
CurrentSpeed
out
TransportPlaySpeed
GetPositionInfo
InstanceID
in
Track
out
CurrentTrack
TrackDuration
out
CurrentTrackDuration
TrackMetaData
out
CurrentTrackMetaData
TrackURI
out
CurrentTrackURI
RelTime
out
RelativeTimePosition
AbsTime
out
AbsoluteTimePosition
RelCount
out
RelativeCounterPosition
AbsCount
out
AbsoluteCounterPosition
GetDeviceCapabilities
InstanceID
in
PlayMedia
out
PossiblePlaybackStorageMedia
RecMedia
out
PossibleRecordStorageMedia
RecQualityModes
out
PossibleRecordQualityModes
GetTransportSettings
InstanceID
in
PlayMode
out
CurrentPlayMode
RecQualityMode
out
CurrentRecordQualityMode
Stop
InstanceID
in
Play
InstanceID
in
Speed
in
TransportPlaySpeed
Pause
InstanceID
in
Seek
InstanceID
in
Unit
in
A_ARG_TYPE_SeekMode
Target
in
A_ARG_TYPE_SeekTarget
Next
InstanceID
in
Previous
InstanceID
in
SetPlayMode
InstanceID
in
NewPlayMode
in
CurrentPlayMode
GetCurrentTransportActions
InstanceID
in
Actions
out
LastChange
string
TransportState
string
STOPPED
PLAYING
PAUSED_PLAYBACK
TRANSITIONING
NO_MEDIA_PRESENT
TransportStatus
string
OK
ERROR_OCCURRED
string
RecordStorageMedium
string
NOT_IMPLEMENTED
string
string
CurrentPlayMode
string
NORMAL
NORMAL
SHUFFLE
REPEAT_ONE
REPEAT_ALL
TransportPlaySpeed
string
1
string
NOT_IMPLEMENTED
string
NOT_IMPLEMENTED
string
NumberOfTracks
ui4
0
1
CurrentTrack
ui4
0
1
1
string
string
string
CurrentTrackURI
string
AVTransportURI
string
string
NextAVTransportURI
string
string
string
string
i4
i4
string
A_ARG_TYPE_SeekMode
string
TRACK_NR
REL_TIME
string
ui4
0
<dlna:X_DLNADOC xmlns:dlna=“urn:schemas-dlna-org:device-1-0”>DMR-1.50</dlna:X_DLNADOC>
pnpx:X_compatibleIdMS_DigitalMediaDeviceClass_DMR_V001
</pnpx:X_compatibleId>
pnpx:X_deviceCategoryMediaDevices
</pnpx:X_deviceCategory>
pnpx:X_hardwareIdBridgecoCE2DM870_0xBD VEN_14E7&DEV_0001&REV_01
</pnpx:X_hardwareId>
df:X_deviceCategoryMultimedia.DMR
</df:X_deviceCategory>
qq:X_QPlay_SoftwareCapabilityQPlay:1</qq:X_QPlay_SoftwareCapability>
smsc:ProductCapSeekOnPaused,WHA</smsc:ProductCap>
CP-800
B&W Group Ltd
CP-800 Stereo Preamp Processor
CP-800
CP-800
D81EDE20BEFB
123810928305
image/jpeg
48
48
24
/BCO_device_sm_icon.jpg
image/jpeg
120
120
24
/BCO_device_lrg_icon.jpg
image/png
48
48
24
/BCO_device_sm_icon.png
image/png
120
120
24
/BCO_device_lrg_icon.png
/RenderingControl/desc.xml
/RenderingControl/ctrl
/RenderingControl/evt
/ConnectionManager/desc.xml
/ConnectionManager/ctrl
/ConnectionManager/evt
/AVTransport/desc.xml
/AVTransport/ctrl
/AVTransport/evt
urn:schemas-smsc-com:service:X_WholeHomeAudio:1
urn:schemas-smsc-com:serviceId:X_WholeHomeAudio:1
/WholeHomeAudio/desc.xml
/WholeHomeAudio/ctrl
urn:tencent-com:service:QPlay:1
urn:tencent-com:serviceId:QPlay
/QPlay/desc.xml
/QPlay/ctrl
UPnP devices found : 3
Device #0: ID 0x0 Yamaha UID: uuid:9ab0c000-f668-11de-9976-00a0defd1eda Location: http://192.168.1.4:49154/MediaRenderer/desc.xml
Device #1: ID 0x0 [LG] webOS TV OLED65C8PUA UID: uuid:540ff059-7f41-66cd-7794-aaeb571e30d8 Location: http://192.168.1.17:1284/
Device #2: ID 0x0 CP-800 UID: uuid:5f9ec1b3-ed59-1900-4530-d81ede20a760 Location: http://192.168.1.2:8080/description.xml
Max. memory for audio buffers: 10028MB
Device #0: ID 0x4a Mac mini Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. Mac mini Speakers
When you change your output to Airplay with Pandora, does MacOS is completely switched to Airplay? You can see this in the sound output of your Mac settings.
The “Sound Output” on the MiniMac’s settings always show Airplay regardless of using Studio, 3.5.5, or Pandora. I don’t use Airplay to connect Audirvana to the Mac or the Mac’s sound output to connect Audirvana to the audio device. I use an Ethernet connection for Audirvana, and Airplay for Pandora or other Airplay sources. Airplay does nor support HiRes playback, that’s why I use Ethernet (Hardwired) for Audirvana.
For Airplay connected devices, wifi is used for the audio connection - there are no audio connections between the MiniMac and the audio device.
Hallo Antoine, i got Problems unlook to get Music played from my NAS or Radio please tell me how i can unlook to play Music.
Heinz
Can you open Audirvana settings and take a look at the selected device while you have this behavior? What is the device selected when the issue occur?
The device selected is the Audio Device (CP-800) and the connection shows Ethernet. This info does not change while the connection problem occurs.
Antoine, I’ve loaded the latest update to Studio, and there is no change in behavior. It still does not release my audio device. AV 3.5 continues to work, but my subscription to Studio is going to waste.
Do you have Audirvāna 3.5 with your device selected opened when you use your device in Audirvāna Studio?
In case my earlier reply did not post - I always quit any running versions of AV before starting the other version.
Antoine, I’ve updated Studio to the latest version and updated the Remote for IOS devices. The problem persists and may be worse. If AS is running it takes control of my UPnP device and won’t let me change the input of the UPnP device to a non-Ethernet source using the Audio Devices own remote app. I have to shut down AS to regain control of the Audio Device
Antoine, Studio is even worse now. It takes control of my audio unit and won’t release it. I can’t even turn off the audio unit with its own remote control. AVS turns it back on. I still have to quit AVS to connect any other audio source to it. While using AVS, not works fine. I like the added functionality, but since I run AVS on a headless Mac Mini, its very difficult to turn quit AVS.
