Has anyone else noticed that Audirvana 2.9.6 takes an unusually long time to start? I get perhaps 30 seconds of beach ball on my M4 Mac before the program is fully launched. As far as I know, the software is not doing any indexing or other tasks that might slow it down. Thanks for any help.
Maybe this has something to do with that?
On my computer Audirvana Origin and Audirvana Studio both start just as quick as before the update, so no problem here. I am using Windows 11 not a Mac.
Seeing the answer of @Amarok1969 in the post above me, maybe it is just a one time thing?
I’m using Origin 2.5.20 and the same problem. Start about 40 seconds. Before 2.5.19 about 5 seconds
succede anche a me (mac os)
No problem here macOS 15.3, Audirvāna Studio 12.9.6
@bostonbenny
Please paste your debug information report here so folks can best provide insights… It is found here: Settings → My Account → Help → Debug info
Audirvana Studio 2.9.6 (20907)
macOS 14.7.3 ARM64 with 64GB physical RAM
Connected account of : Giovanni Zucconi
Bandwidth at 0dB = 99.5%
Phase = 66%
Sync list: 5 folders
AUTO: /Volumes/Musica_Hi_Res/Musica_Blues
AUTO: /Volumes/Musica_Hi_Res/Musica_Classica
AUTO: /Volumes/Musica_Hi_Res/Musica_Disco
AUTO: /Volumes/Musica_Hi_Res/Musica_Jazz
AUTO: /Volumes/Musica_Hi_Res/Musica_Pop, Rock, Leggera
Sort and display order: it
Library database path: /Users/giovannimariazucconi/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 2963
Listening on on port 61479
Font size: regular
Streaming
My Music
Radios
Podcasts
Use Apple Remote: yes
Number of paired remotes: 2
Screen saver disabled: yes
Max. memory for audio buffers: 8484MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
AudioQuest AudioQuest DragonFly Red v1.0
Model UID:AudioQuest DragonFly Red v1.0:21B4:0082
UID:AppleUSBAudioEngine:AudioQuest:AudioQuest DragonFly Red v1.0:AQDFRD0100033928:1
Active Sample Rate: 96kHz
Selected device:Studio Display Speakers
Model name: Apple Inc. Studio Display Speakers
Model UID: Studio Display Audio Control:05AC:1114
UID: AppleUSBAudioEngine:Apple Inc.:Studio Display:00008030-001A4C48112A802E:8,9
USB Vendor ID: 0x05ac
USB Product ID: 0x1114
ID 0x36
Unhandled (PCM conversion) with boost gain of 2dB
Multichannel: 8 channels
Channel bitmap: Ox3f, layout:
Channel 2 mapped to 2
Channel 3 mapped to 3
Channel 4 mapped to 4
Channel 5 mapped to 5
Channel 6 unused
Channel 7 unused
Number of channels: 8
Simple stereo device: No
Number of active channels: 8, in 1 stream(s)
Channel #6 :Stream 0 channel 6
Channel #7 :Stream 0 channel 7
Stream ID 0x37 8 channels starting at 1
8 virtual formats:
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 96kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 88.2kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 44.1kHz
8 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 96kHz
8 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 88.2kHz
8 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 48kHz
8 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 44.1kHz
8 physical formats
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 96kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 88.2kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 48kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 44.1kHz
Device #0: ID 0x36 Studio Display Speakers
Device #1: ID 0x52 Altoparlanti Mac Studio
Model UID: Speaker
UID: BuiltInSpeakerDevice
Model name: Apple Inc. Altoparlanti Mac Studio
Selected Network interface: Wi-Fi
Wi-Fi
UPnP devices found : 1
Device #0: ID 0x0 : MS120
UID: uuid:b504735e-4129-4507-be5e-30325a177bda
Location: http://192.168.178.22:16500/b504735e-4129-4507-be5e-30325a177bda.xml
Manufacturer: ATOLL Electronique
Model name: MS120
I had the same problem. I let CCleaner run and clean the Audirvana cache on my Mac (part of their quick scan) and the problem was gone. Perhaps this helps.
Thanks. It’s good to know about CCleaner. Audirvana support provided a link to a beta version of Studio that seems to have resolved the issue for me.
