my Audirvana Studio goes from two channels to one (IE the right speaker stops playing) during play or when I choose a new track or album from my favourites. I have tried deleting the program and reinstalling it and have also tried the previous version and recent updates. I am using it with windows 10 into my DAC via USB to stream via Qobuz. Anyone else have this issue?
I’ve only had a couple of momentary blips never a long enough event to delve into.
Please post your debug reports and the community feedback might be helpful.
Are you upsampling? Perhaps try disabling it.
I have to reboot to get two channels again and then I’m lucky to be able to listen to an entire album. I change the upsampling but have not been able to try it since.
Audirvana Studio 2.2.3 (20203)
Windows 10 (19044) with 16GB physical RAM
AUTO: C:\Users\New User\Desktop
Library database path: C:\Users\New User\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 192.168.24.232 on port 62653
Max. memory for audio buffers: 10024MB
Speaker/HP (Realtek High Definition Audio)
Model UID:HDAUDIO\FUNC_01&VEN_10EC&DEV_0293&SUBSYS_17AA5053&REV_1000
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{c8573fef-6495-4b66-8f3e-bb14de2d8470}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Selected device:Speaker/HP (Realtek High Definition Audio)
Manufacturer: Realtek
Model UID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0293&SUBSYS_17AA5053&REV_1000
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{c8573fef-6495-4b66-8f3e-bb14de2d8470}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Kernel Streaming capable
4 available sample rates up to 192000Hz
Simple stereo device: No
Device #0: Speaker/HP (Realtek High Definition Audio)
Chromecast devices found : 7
Device #0: Front door TV
Model name: Chromecast
Device #1: Bedroom TV
Device #2: InRoom Chromecast TV 404
Device #3: InRoom Chromecast TV 716
Device #4: InRoom Chromecast TV 418
Device #5: InRoom Chromecast TV 805
Device #6: InRoom Chromecast TV 305
