Hi, my old mac is broken so i need to install again audirvana to a new one. I cannot find the key, how do i restore it?
Thx
Thx
Hi Thomasios,
I’m not an expert on this, and I guess that the tech support is most probably off today. But you can try to reset your installations on that page:
Try what @patifr suggested. If that does not work send a mail to support@audirvana.com . They are the tech support.
