I am having these issues only when using audirvana. I have not been able to solve this issue with information from others who have posted this question. I am not upsampling and have disabled all plugins. I have tried all usb ports on my computer. I don’t have another cable to test with, waiting for one in the mail. I have tried wasapi, asio and kernel streaming.
Hello @THEYiftah nice to see you post sorry that you’re having a problem. Sounds like you have been using the search function. Please post your debug reports and explain in a bit more detail about your system hardware.
I’m also getting repeated popping, like there’s dirt in a vinyl groove. Happens with all inputs. Reloading the app does not help.
Audirvana Studio 2.2.3 (20203)
Windows 10 (19044) with 8GB physical RAM
Connected account of : Yiftah Cooper
Phase minimum phase
Max allowed volume: 95.1648
Sync list: 0 folders
Library database path: C:\Users\Yifta\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 2a0d:6fc0:8a7:ed00:322e:1297:16d0:c489 on port 49806
Max. memory for audio buffers: 6956MB
Digital Output (Chord Async USB 44.1kHz-768kHz)
Model UID:USB\VID_245F&PID_0815&REV_0197
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{06428237-689e-4f4e-b43c-8d0924650c21}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Selected device:Digital Output (Chord Async USB 44.1kHz-768kHz)
Manufacturer: Chord Electronics Ltd.
Model name: Qutest
Model UID: USB\VID_245F&PID_0815&REV_0197
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{06428237-689e-4f4e-b43c-8d0924650c21}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
USB Vendor ID: 0x245f
USB Product ID: 0x0815
Kernel Streaming capable
Simple stereo device: No
2 ch Integer PCM 24bit little endian 352.8kHz
2 ch Integer PCM 24bit little endian 384kHz
2 ch Integer PCM 24bit little endian 705.6kHz
2 ch Integer PCM 24bit little endian 768kHz
Device #0: Speaker / Headphone (Realtek(R) Audio)
Manufacturer: Realtek
Model UID: INTELAUDIO\FUNC_01&VEN_10EC&DEV_0285&SUBSYS_103C85E6&REV_1000
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{3f660f31-5586-4fee-9988-4bdde3553cd4}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Model name: Intel High Definition Audio
Device #1: Digital Output (Chord Async USB 44.1kHz-768kHz)
Model name: Qutest
Chromecast devices found : 1
Device #0: Allony
Model name: yes
Thanks @OffRode !
Adjust buffer to 4000 mb
Set volume to 100%
Give these changes a try and let us know if it helps
Always!
Maybe a hard reset of the Chord device?
It happens to me with a Marantz NA11-S1: the only solution is to unplug the device from the power source, wait around 10 s, and replug and restart.
Still happens after all these fixes were tried
I know may sound stupid but install this: Download K-Lite Codec Pack Mega
It’s a codec pack as you probabily know. Should be not related to Audirvana but… Well, few months ago I observed that mp3 content (radios, local files) played in Audirvana is full of noise. Tried many things without success. After updating K-Lite Codec Pack BOOM! - problem solved. Maybe Audirvana use codecs from the system, maybe something else, I don’t know.
thanks @DGrigorescu I will try this tomorrow.
Still having this problem unfortunately
Tried it, doesn’t work.
Hi @THEYiftah,
Do you have †his issue while you output to your
using WASAPI?
@Antoine my speaker headphone realtek audio is too poor to hear porpperly is there is static or just the normal low quality.
Doesn’t work unfortunately
