Loud Crack When Starting DSD Upsampling
Hi,
First post as a trial user of AS, I’ve noticed an issue if I choose to upsample my tracks to DSD128+ with my Topping DAC and ASIO driver. It appears that the software drops back to dsd64 between play sessions, then with the jump to a higher resample rate when playback starts, there is an audible crack, not to dissimilar to a needle hitting vinyl.
The options to mute or add latency don’t appear to be active for DSD. Roon and JRiver don’t exhibit the same behaviour. PCM upsampling is fine even with those options off.
I noticed a 4 year old topic with the same issue, so has this never been fixed?
Cheers
Welcome… Please paste your Debug information here, so folks can help as best possible. It is found here: System → My Account → Help → Debug info
Sure, here it is
Audirvana Studio 2.8.1 (20801)
Windows 10 (19045) with 8GB physical RAM
Connected account of : XXXXXXXXXX
Available network interfaces:
ResurrectionHub5 ({xxxxxxxxxxxxxxxxxxx}) is private
Active profile types: all
Private profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Third party firewall installed and registered in place of Windows Defender:
Avast Antivirus
r8brain to DSD256 with filter type B 7th order
Sync list: 2 folders
AUTO: \DISKSTATION\XXXXXXXXX
AUTO: \DiskStation\XXXXXXXXX
Library database path: C:\Users\XXXXXXXXXXXXX.sqlite
Fingerprinting track 7745/34522 : \Gorillaz\Humanz Deluxe\7 Submission feat. Danny Brown and Kelela.flac
Listening on XXXXXXXXXXXXX on port 56281
Font size: large
My Music
Radios
Podcasts
Streaming
Number of paired remotes: 1
Screen saver disabled: no
Max. memory for audio buffers: 4096MB
Local Audio Engine: ASIO 2
Driver version 1337
Topping USB Audio Device
Model UID:Topping USB Audio Device
Device: 2ch 8bits Integer, 2 bytes per frame 11289.6kHz
Active Sample Rate: 11289.6kHz
Selected device:Topping USB Audio Device
Manufacturer:
Model name: Topping USB Audio Device
Model UID: Topping USB Audio Device
11 available sample rates up to 11289600Hz
5644800
11289600
Raw DSD (msb)
Local devices found : 8
Device #0: JRiver Media Center 20
Manufacturer:
Model UID: JRiver Media Center 20
Model name: JRiver Media Center 20
Device #1: JRiver Media Center 21
Manufacturer:
Model UID: JRiver Media Center 21
Model name: JRiver Media Center 21
Device #2: JRiver Media Center 24
Manufacturer:
Model UID: JRiver Media Center 24
Model name: JRiver Media Center 24
Device #3: JRiver Media Center 30
Manufacturer:
Model UID: JRiver Media Center 30
Model name: JRiver Media Center 30
Device #4: JRiver Media Center 31
Manufacturer:
Model UID: JRiver Media Center 31
Model name: JRiver Media Center 31
Device #5: JRiver Media Center 32
Manufacturer:
Model UID: JRiver Media Center 32
Model name: JRiver Media Center 32
Device #6: OPPO USB AUDIO 2.0 ASIO Driver
Manufacturer:
Model UID: OPPO USB AUDIO 2.0 ASIO Driver
Model name: OPPO USB AUDIO 2.0 ASIO Driver
Device #7: Topping USB Audio Device
Manufacturer:
[quote=“thewardy, post:3, topic:41281”]
[/quote]T
Try adding 1.5s of ‘Sample rate switching latency’ and lowering your playback pre-load RAM allocation to 2GB and turn-off software volume control… Also, I suggest removing JRiver Media Center for best performance.
Makes no difference sadly.
The dac options to add extra time are greyed out in DSD upscale mode.
RAM/Uninstall Jriver made no difference.
It’s easily repeatable just by jumping between a radio station and then a local file, or when first playing a local file from start up. Looks like it’s never been fixed.
Also noticed it’s missed 500 tracks on the import too, must be an unsupported format from decades ago.
Shame as the gui as the gui is nice.
I modulate all PCM files to DSD128 via r8Brain in Audirvana and the Sample rate switching latency setting is fully available to me on macOS…
When the sample-rate changes from PCM to DSD or from DSD to PCM there can be a transient level change pop or tick…
