Hello All,
Looking for some advice on what would be the best way to configure Audirvana so that I can listen at levels to match my other sources. Currently playing through my Naim DAC-V1, the audio is really loud at the 10pm mark on the preamp volume dial compared to say CD or Tuner. Is there a way to easily configure Audirvana to lower this and if so, would this affect the overall sound quality?
Thanks in advance…
Cheers,
Vin.
