Lyngdorf MP60.2.1 is my preferred UPnp player in debugging info but it does not show as an output.
Audirvana Studio 2.6.0 (20600)
macOS 14.1.1 with 16GB physical RAM
Connected account of : Charles Feathers
Sync list: 0 folders
Library database path: /Users/charlesfeathers/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 83
Listening on 127.0.0.1 on port 49558
TIDAL: Connected as PREMIUM
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Use max I/O buffer size: OFF
[UPnP] MP-60-7c7438
Model UID:Lyngdorf MP-60
UID:uuid:887158fb-7ad9-46fe-b6ca-e7f2e3543acf
Active Sample Rate: 48kHz
Selected device:MacBook Air Speakers
Model name: Apple Inc. MacBook Air Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
ID 0x48
Stream ID 0x49 2 channels starting at 1
4 virtual formats:
4 physical formats
Device #0: ID 0x48 MacBook Air Speakers
Model UID: Speaker
Chromecast devices found : 2
Device #0: Family Room Display
Model name: Google Nest Hub
Device #1: Family Room Display 2
Model name: Google Nest Hub Max
