Audirvana Mac Version 3.5.39 (3569)
macOS 10.15.6 with 32768MB RAM
AU plugin #0: Music Effect - FabFilter Pro-Q 3 ()
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
Replay Gain: by album
SW volume control: ON
Manual: (OFFLINE) /Volumes/media/Music
Library database path: /Users/derekseaman/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
SMSL USB AUDIO
Model UID:SMSL USB AUDIO:152A:85DD
UID:AppleUSBAudioEngine:SMSL:SMSL USB AUDIO:120000:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 8 bytes per frame 44.1kHz
Hog Mode is on
Limit bitdepth to 24bit: ON
ID 0x31 SMSL USB AUDIO Manufacturer:SMSL
Model UID:SMSL USB AUDIO:152A:85DD UID:AppleUSBAudioEngine:SMSL:SMSL USB AUDIO:120000:1
Stream ID 0x32 2 channels starting at 1
30 virtual formats:
40 physical formats
Local devices found : 4
Device #0: ID 0x5c BenQ PD2720U Manufacturer: Apple Inc. Model UID: AppleGFXHDA:0 UID: AppleGFXHDAEngineOutputDP:f803:0:{D109-8030-00005445}
Device #1: ID 0x60 BenQ PD2720U Manufacturer: Apple Inc. Model UID: AppleGFXHDA:0 UID: AppleGFXHDAEngineOutputDP:f803:1:{D109-8030-00005445}
Device #2: ID 0x31 SMSL USB AUDIO Manufacturer: SMSL Model UID: SMSL USB AUDIO:152A:85DD UID: AppleUSBAudioEngine:SMSL:SMSL USB AUDIO:120000:1
Device #3: ID 0x50 MacBook Pro Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
UPnP devices found : 2
Device #0: ID 0x0 Denon AVR-X4200W UID: uuid:5f9ec1b3-ff59-19bb-8530-0005cd6203c6 Location: http://10.13.2.63:8080/description.xml
Device #1: ID 0x0 OPPO UDP-203 UID: uuid:3049f58a-1dd2-11b2-87bc-e475aaac0f3f Location: http://10.13.2.105:49152/dmr_oppo.xml
