Hello
Will Audirvana work with a Macbook and a Naim Unitilite, set up as Upnp? Any hints? I’ve tried other streamers but no luck! Thank you.
Hello
You will be able to see your device in the audio output menu of Audirvana if it’s available on your local network:
Don’t know about a Unitilite, but UPnP works perfectly with my Unity Nova.
