Hi there, hoping someone can help me out here. I use Audirvana with a Focal Arche via USB, what I’ve noticed is, when I select the Arche as the output in Audirvana, music will play fine, but in the Audio MIDI Setup application, the device which is ‘playing’ is the Built-In-Output which limits the output to 24/96. If I try to select the Arche in Audirvana and as the Output Device on the Mac, I get no audio, as Audirvana will not load the track (I’m solely using Qobuz btw). I would expect to see the Arche playing as the Output Device in the Audio MIDI Setup application, but I don’t. Am I doing something wrong or is this expected behavior?
Hello @nick2413,
Can you send me a copy of the “Debug Info” while you have selected your Arche in Audirvana? You can get it in Audirvana Settings>General>Debug Info
Thank you as always Damien, pasting below:
macOS 10.15.7 with 8192MB RAM
Registered to Nick Little
Per track: OFF
AUTO: /Users/nickspersonalmac/Downloads
Library database path: /Users/nickspersonalmac/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
FOCAL ARCHE Audio 2.0
Model UID:FOCAL ARCHE Audio 2.0:152A:87A0
UID:AppleUSBAudioEngine:FOCAL:FOCAL ARCHE Audio 2.0:14100000:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 8 bytes per frame 44.1kHz
Hog Mode is on
ID 0x3a FOCAL ARCHE Audio 2.0 Manufacturer:FOCAL
Model UID:FOCAL ARCHE Audio 2.0:152A:87A0 UID:AppleUSBAudioEngine:FOCAL:FOCAL ARCHE Audio 2.0:14200000:1
Stream ID 0x3b 2 channels starting at 1
30 virtual formats:
40 physical formats
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 768kHz
Device #0: ID 0x30 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:93 UID: AppleHDAEngineOutput:1B,0,1,1:0
Device #1: ID 0x3a FOCAL ARCHE Audio 2.0 Manufacturer: FOCAL Model UID: FOCAL ARCHE Audio 2.0:152A:87A0 UID: AppleUSBAudioEngine:FOCAL:FOCAL ARCHE Audio 2.0:14200000:1
UPnP devices found : 1
Device #0: ID 0x0 Super-9CC9 UID: uuid:5F9EC1B3-ED59-79BB-4530-0011F6A89CC9 Location: http://192.168.86.65:8080/description.xml
Have you tried to enable DSD over PCM in the audio output settings?
macOS is not able to send raw DSD streams. That’s why the DSD over PCM standard has been developed: to send raw DSD in a fake PCM stream.
To identify it as such, there are 8 bit markers in it.
And the presence of these markers doubles the need of bandwidth, thus explaining why on a mac only half of the max DSD rate is available.
Thanks as always for the reply Damien, I’m not sure we’re on the same page though, changing DSD to over PSM hasn’t made a difference. See the screenshot below, music is playing through the Arche, but in Audio MIDI settings there is a small speaker next to the Built in Output, which suggests the audio is being routed through that limited to 24/48:
This is normal, Audirvana takes exclusive access to the audio device (i.e. your DAC) during playback to be able to implement its sound signal optimizations.
Audirvana takes exclusive access to the audio device (usually your DAC) to be able to apply its advanced optimizations during playback. MacOs then tries to find another available audio device.
When playback stops, Audirvana restores access to the audio device, and any other application can then use it.
