Yes connected locally via USB
Audirvana Studio 2.3.2 (20302)
macOS Version 13.4 (Build 22F66) with 16GB physical RAM
Connected account of :
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
Sync list: 0 folders
Library database path: /Users//Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 1447
Listening on 127.0.0.1 on port 49238
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Use max I/O buffer size: OFF
Chord Electronics Ltd Qutest
Model UID:Qutest:245F:0815
UID:AppleUSBAudioEngine:Chord Electronics Ltd:Qutest:413-001:2
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 48kHz
Active Sample Rate: 48kHz
Hog Mode is on
Selected device:Qutest
Manufacturer: Chord Electronics Ltd
Model name: Chord Electronics Ltd Qutest
Model UID: Qutest:245F:0815
UID: AppleUSBAudioEngine:Chord Electronics Ltd:Qutest:413-001:2
USB Vendor ID: 0x245f
USB Product ID: 0x0815
ID 0x30
11 available sample rates up to 768000Hz
32000
Stream ID 0x31 2 channels starting at 1
22 virtual formats:
22 physical formats
Device #0: ID 0x30 Qutest
Device #1: ID 0x4d iMac Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Model name: Apple Inc. iMac Speakers
