Hi,
I’m trying Audirvana but with my DAC is DSD not working. Is Impacto not compatible with Audirvana ?
Debug-INFO.
Mac Version 3.5.44 (3574)
macOS 11.2.3 with 4096MB RAM
Die Testversion verwendet eine Demo-Lizenz
SW volume control: ON
AUTO: /Volumes/music/Klangproben_HIRES
iTunes/Music library synchronization: last synchronized on Tue Apr 13 18:01:49 2021
Library database path: /Users/Ron/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 1024MB
Impacto
Model UID:Impacto:2E50:0001
UID:AppleUSBAudioEngine:beyerdynamic GmbH & Co. KG:Impacto:717673050521:1
ID 0x95 Impacto Manufacturer:beyerdynamic GmbH & Co. KG
Model UID:Impacto:2E50:0001 UID:AppleUSBAudioEngine:beyerdynamic GmbH & Co. KG:Impacto:717673050521:1
Stream ID 0x96 2 channels starting at 1
24 virtual formats:
32 physical formats
Device #0: ID 0x31 Ausgang (integriert) Manufacturer: Apple Inc. Model UID: AppleHDA:114 UID: AppleHDAEngineOutput:1B,0,1,1:0
Device #1: ID 0x95 Impacto Manufacturer: beyerdynamic GmbH & Co. KG Model UID: Impacto:2E50:0001 UID: AppleUSBAudioEngine:beyerdynamic GmbH & Co. KG:Impacto:717673050521:1
UPnP devices found : 2
Device #0: ID 0x0 AFTS-184 UID: uuid:be32a51c-a4e0-4fd1-b079-2f3b79299f3c Location: http://192.168.178.189:2030/
Device #1: ID 0x0 PCH-C200 (E9CB3EFF-55C9-494C-A6DF-5FFEBE0A96C4) UID: uuid:E9CB3EFF-55C9-494C-A6DF-5FFEBE0A96C4 Location: http://192.168.178.23:6357/
