Good evening from Quebec.
I spent the last 2 hours trying to get a DSD files to play on my Preamplifier McIntosh C2700 with the its new DA2 Dac.
I use the latest version of Audirvana on my MacBook Pro and send the music via USB to the DA2 (Dac).
DSD128 files is playing on Audirvana.
But it shows on my C2700 352.8 and no sound.
Do you know what to do.
My DA2 is DSD512 compatible…
Audirvana Mac Version 3.5.33 (3563)
macOS 10.15.4 with 16384MB RAM
Registered to Christopher Guilbaud-Mc Harg
Per track: OFF
Sync list: 2 folders
Manual: (OFFLINE) /Volumes/Digital Medias/Collection de CD - APPLE LOSSLESS
Manual: (OFFLINE) /Volumes/Digital Medias/iTunes
iTunes/Music library synchronization: last synchronized on Thu Jun 20 15:25:33 2019
Library database path: /Users/Christo/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 15360MB
McIntosh
Model UID:McIntosh:2AFD:000B
UID:AppleUSBAudioEngine:DA2:McIntosh:14100000:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 8 bytes per frame 352.8kHz
Active Sample Rate: 352.8kHz
Hog Mode is on
ID 0x29 McIntosh Manufacturer:DA2
Model UID:McIntosh:2AFD:000B UID:AppleUSBAudioEngine:DA2:McIntosh:14200000:1
30 virtual formats:
40 physical formats
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 768kHz
Device #0: ID 0x33 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:123 UID: AppleHDAEngineOutput:1B,0,1,1:0
Device #1: ID 0x29 McIntosh Manufacturer: DA2 Model UID: McIntosh:2AFD:000B UID: AppleUSBAudioEngine:DA2:McIntosh:14200000:1
UPnP devices found : 1
Device #0: ID 0x0 BRAVIA KDL-65W950B UID: uuid:00000000-0000-1010-8000-fcf15205f0fb Location: http://192.168.2.12:52323/dmr.xml
