Hello Damien,
Thanks. After a reboot of my computer and my Hegel amplifier I could stream music via UPnP. However, approx. every five minutes there is a short music dropout. Please find below the Debug Info. BTW, I am using a MacBook Pro Late 2013 not 2012 as indicated above…
Best regards,
Ralf
macOS 11.1.0 with 8192MB RAM
Die Testversion verwendet eine Demo-Lizenz
AUTO: /Volumes/Musik/Musik HQ
Library database path: /Users/Ralf/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Preferred device: HEGEL Model UID:Hegel HEGEL UID:uuid:1cfb18fe-1dd2-11b2-99c9-8f57da743e33
UPnP device at http://192.168.178.67:38400/description.xml
ID 0x0 HEGEL Manufacturer:Hegel
Volume control: No
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::application/ogg:
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
12 virtual formats:
0 physical formats
NrTracks: 0
MediaDuration: 00:00:00
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
<?xml version="1.0"?>
1
0
SetAVTransportURI
InstanceID
in
A_ARG_TYPE_InstanceID
CurrentURI
in
AVTransportURI
CurrentURIMetaData
in
AVTransportURIMetaData
GetMediaInfo
InstanceID
in
NrTracks
out
NumberOfTracks
MediaDuration
out
CurrentMediaDuration
CurrentURI
out
AVTransportURI
CurrentURIMetaData
out
NextURI
out
NextAVTransportURI
NextURIMetaData
out
NextAVTransportURIMetaData
PlayMedium
out
PlaybackStorageMedium
RecordMedium
out
RecordStorageMedium
WriteStatus
out
RecordMediumWriteStatus
GetTransportInfo
InstanceID
in
out
TransportState
out
TransportStatus
CurrentSpeed
out
TransportPlaySpeed
GetPositionInfo
InstanceID
in
Track
out
CurrentTrack
TrackDuration
out
CurrentTrackDuration
TrackMetaData
out
CurrentTrackMetaData
TrackURI
out
CurrentTrackURI
RelTime
out
RelativeTimePosition
AbsTime
out
AbsoluteTimePosition
RelCount
out
RelativeCounterPosition
AbsCount
out
AbsoluteCounterPosition
GetDeviceCapabilities
InstanceID
in
PlayMedia
out
PossiblePlaybackStorageMedia
RecMedia
out
PossibleRecordStorageMedia
RecQualityModes
out
PossibleRecordQualityModes
GetTransportSettings
InstanceID
in
PlayMode
out
CurrentPlayMode
RecQualityMode
out
CurrentRecordQualityMode
SetPlayMode
InstanceID
in
NewPlayMode
in
CurrentPlayMode
Stop
InstanceID
in
Play
InstanceID
in
Speed
in
TransportPlaySpeed
Pause
InstanceID
in
Seek
InstanceID
in
Unit
in
A_ARG_TYPE_SeekMode
Target
in
A_ARG_TYPE_SeekTarget
Next
InstanceID
in
Previous
InstanceID
in
GetCurrentTransportActions
InstanceID
in
Actions
out
TransportState
string
STOPPED
PAUSED_PLAYBACK
PLAYING
TRANSITIONING
NO_MEDIA_PRESENT
TransportStatus
string
OK
ERROR_OCCURRED
string
UNKNOWN
CD-DA
DVD-VIDEO
HDD
NONE
RecordStorageMedium
string
NOT_IMPLEMENTED
string
UNKNOWN
CD-DA
DVD-VIDEO
HDD
string
NOT_IMPLEMENTED
CurrentPlayMode
string
NORMAL
SHUFFLE
REPEAT_ONE
REPEAT_TRACK
REPEAT_ALL
NORMAL
TransportPlaySpeed
string
1
string
NOT_IMPLEMENTED
string
NOT_IMPLEMENTED
string
NOT_IMPLEMENTED
NumberOfTracks
ui4
0
1
CurrentTrack
ui4
0
1
1
string
string
string
CurrentTrackURI
string
AVTransportURI
string
string
NextAVTransportURI
string
string
string
string
i4
i4
string
LastChange
string
A_ARG_TYPE_SeekMode
string
ABS_COUNT
TRACK_NR
REL_TIME
string
ui4
1
0
DMR-1.50
QPlay:2
HEGEL
Hegel
http://www.hegel.com
H120
H120
1.0
/RenderingControl.xml
/RenderingControl
/RenderingControl/eventSub
/AVTransport.xml
/AVTransport
/AVTransport/eventSub
/ConnectionManager.xml
/ConnectionManager
/ConnectionManager/eventSub
urn:schemas-tencent-com:service:QPlay:1
urn:tencent-com:serviceId:QPlay
/QPlay.xml
/QPlay
/QPlay/eventSub
UPnP devices found : 1
Device #0: ID 0x0 HEGEL UID: uuid:1cfb18fe-1dd2-11b2-99c9-8f57da743e33 Location: http://192.168.178.67:38400/description.xml
Device #0: ID 0x31 Ausgang (integriert) Manufacturer: Apple Inc. Model UID: AppleHDA:93 UID: AppleHDAEngineOutput:1B,0,1,1:0
