I am running Audirvana on a MacBook pro (Catalina OS). The issue is that if I move or delete a file or folder in the Finder, Audirvana stops playing immediately and I need to restart playing. Basically, if Audirvana is playing I can’t do anything in Finder without making Audirvana stop.
Barnaby
I have a similar set-up. In Audirvana ‘Sysoptimiser’ various settings increasingly disable Apple basic operations to favour audio reproduction. Re-check what you have enabled here and ‘back-off’ the optimisations till the stuff you want to work - works !
I suspect the full-on optimisation only benefits very Hi-Def playback.
