I’ve tried everything (that I’m willing to or can think of) but cannot get any sound, so I have yet to hear the Audivana magic. Am able to play audio via iPad Pro but not via MacBook Pro (2015).
Are there any clues in my most recent debug?:
Audirvana Origin 1.0.6 (10006)
macOS Version 12.6 (Build 21G115) with 16GB physical RAM
Effects plugins ACTIVE in offline mode with legacy macOS API
No plugin active
Sync list: 2 folders
AUTO: /Users/jeff/HiFi
AUTO: /Users/jeff/iCloud Drive (Archive)/Documents/Documents - MacBook Pro/HiFi
iTunes/Music library synchronization: last synchronized on Tue Aug 23 20:37:03 2022
Library database path: /Users/jeff/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 56860
SMSL SMSL USB AUDIO
Model UID:SMSL USB AUDIO:152A:85DD
UID:AppleUSBAudioEngine:SMSL:SMSL USB AUDIO:14100000:1
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 352.8kHz
Active Sample Rate: 352.8kHz
Hog Mode is on
ID 0x51 SMSL USB AUDIO
Manufacturer: SMSL
Model Name: SMSL USB AUDIO
Model UID: SMSL USB AUDIO:152A:85DD
UID: AppleUSBAudioEngine:SMSL:SMSL USB AUDIO:14100000:1
Audio buffer frame size : 212 to 4096 frames
Stream ID 0x52 2 channels starting at 1
20 virtual formats:
20 physical formats
Local devices found : 3
Device #0: ID 0x47 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:128 UID: AppleHDAEngineOutput:1B,0,1,1:0 Model Name: Apple Inc. Built-in Output
Device #1: ID 0x51 SMSL USB AUDIO Manufacturer: SMSL Model UID: SMSL USB AUDIO:152A:85DD UID: AppleUSBAudioEngine:SMSL:SMSL USB AUDIO:14100000:1 Model Name: SMSL USB AUDIO
Device #2: ID 0x36 Microsoft Teams Audio Manufacturer: Microsoft Corp. Model UID: MSLoopbackDriverDevice_ModelUID UID: MSLoopbackDriverDevice_UID Model Name: Microsoft Corp. Microsoft Teams Audio
UPnP devices found : 1
Device #0: ID 0x0 [TV] Familyroom TV UID: uuid:c3aa4d5b-76aa-4314-9e11-d0edcd351076
