I have been happily using Studio several months and have not had any problems until today.
While streaming Qobuz, it will play a few songs and then all of a sudden there will be very load garbled distortion. I have not changed any settings for several months either.
This is not a one time occurence, as I closed Studio when it happened the first time. I thought it may be because it was open for nearly a week. I restarted it and after a couple songs, it did it again on a different album.
Any help would be greatly appreciated,
Here is a debug, directly after occurence:
Audirvana Studio 1.8.1 (10801)
macOS 10.15 with 24GB physical RAM
r8brain with Power Of Two upsampling
AUTO: /Users/dannybezak/Documents/Music
Library database path: /Users/dannybezak/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 56215
Max. memory for audio buffers: 5720MB
CA CA DACMAGIC 200M 2.0
Model UID:CA DacMagic 200M 2.0:22E8:DAC2
UID:AppleUSBAudioEngine:CA:CA DacMagic 200M 2.0:14200000:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 8 bytes per frame 768kHz
Active Sample Rate: 768kHz
Hog Mode is on
ID 0x53 CA DacMagic 200M 2.0
Manufacturer: CA
Model Name: CA DacMagic 200M 2.0
Model UID: CA DacMagic 200M 2.0:22E8:DAC2
UID: AppleUSBAudioEngine:CA:CA DacMagic 200M 2.0:14200000:1
MQA Decoder device
Stream ID 0x54 2 channels starting at 1
30 virtual formats:
40 physical formats
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 768kHz
Local devices found : 3
Device #0: ID 0x44 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:7 UID: AppleHDAEngineOutput:1B,0,1,2:0 Model Name: Apple Inc. Built-in Output
Device #1: ID 0x53 CA DacMagic 200M 2.0 Manufacturer: CA Model UID: CA DacMagic 200M 2.0:22E8:DAC2 UID: AppleUSBAudioEngine:CA:CA DacMagic 200M 2.0:14200000:1 Model Name: CA DacMagic 200M 2.0
Device #2: ID 0x33 eqMac2 Manufacturer: Bitgapp Model UID: com_bitgapp_eqMac2Driver:eqMac2 UID: EQMAC2.1_DRIVER_ENGINE Model Name: Bitgapp eqMac2
