I am getting close to the end of my trial. Up until this point, there have been little to no issues. I was getting ready to subscribe.
What happened, playing various tracks adding them to the play que via the remote iOS app, it suddenly started playing the wrong tracks and not only that, but with major distortion.
I should add, this was being used streaming Tidal.
Going to the Mac and hitting a new album to play from Tidal and all was back to normal?
Here is the debug info:
Audirvana Mac Version 1.5.7 (10507)
macOS 10.15.7 with 24576MB RAM
Connected account: [email protected] (Dan Bezak)
No plugin active
Bandwidth at 0dB = 99.5%
Phase = 66%
SW volume control: ON
AUTO: /Users/dannybezak/Documents/Music
iTunes/Music library synchronization: last synchronized on Sat Jul 10 09:49:45 2021
Library database path: /Users/dannybezak/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 55421
Max. memory for audio buffers: 21504MB
CA CA DACMAGIC 200M 2.0
Model UID:CA DacMagic 200M 2.0:22E8:DAC2
UID:AppleUSBAudioEngine:CA:CA DacMagic 200M 2.0:14200000:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 8 bytes per frame 44.1kHz
Hog Mode is on
ID 0x5b CA DacMagic 200M 2.0
Manufacturer: CA
Model Name: CA DacMagic 200M 2.0
Model UID: CA DacMagic 200M 2.0:22E8:DAC2
UID: AppleUSBAudioEngine:CA:CA DacMagic 200M 2.0:14200000:1
MQA Decoder device
Stream ID 0x5c 2 channels starting at 1
30 virtual formats:
40 physical formats
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 768kHz
Local devices found : 3
Device #0: ID 0x46 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:7 UID: AppleHDAEngineOutput:1B,0,1,2:0 Model Name: Apple Inc. Built-in Output
Device #1: ID 0x5b CA DacMagic 200M 2.0 Manufacturer: CA Model UID: CA DacMagic 200M 2.0:22E8:DAC2 UID: AppleUSBAudioEngine:CA:CA DacMagic 200M 2.0:14200000:1 Model Name: CA DacMagic 200M 2.0
Device #2: ID 0x35 eqMac2 Manufacturer: Bitgapp Model UID: com_bitgapp_eqMac2Driver:eqMac2 UID: EQMAC2.1_DRIVER_ENGINE Model Name: Bitgapp eqMac2
